Old 12-15-2008, 02:53 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Does the SVX have Snap Oversteer?
Originally Posted by TomsSVX View Post
when in doubt... throttle out right??? Just make sure that building can move in time!!!
Damn straight!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-15-2008, 02:57 PM
Originally Posted by SVXRide View Post
Damn straight!
-Bill
As long as straight isn't directed at a WALL!!!
Old 12-15-2008, 03:03 PM
kcbsvx's Avatar
kcbsvx kcbsvx is offline
Now down to only ONE!
I have experienced instant oversteer only twice in my SVX on dry pavement. Each time was on a diminishing radius on ramp. Two different ramps. One level and only slightly cambered that I drive hard all the time, and one not cambered and with a good uphill grade that I rarely drive (and never before nor since accelerated like that on).
Twice I was accelerating strongly and approaching the merge at about 8.5-9/10ths when I saw a slow car on the highway that I would have pulled in front of in an ungentilemanly fashion. On the level ramp I just snapped off the gas- no brakes. On the uphill ramp I dropped the gas and touched the brakes. Both times the back end stepped out sharply and I had to countersteer and catch it- to which the SVX responded without drama.
Now in the snow...
Christian-
96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC.
2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock
1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods
2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock
