Old 03-26-2008, 07:05 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
Replacing AWD clutches?
Can someone throw out a rough estimate on the costs involved in replacing transfer clutches on a AWD that is only running in FWD?
Thanks
1994 subaru svx le 112k
Old 03-26-2008, 07:08 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
LAN, YT, and OT are the only ones I know who have done this, outside of trans shops.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-26-2008, 07:09 PM
Depends, it is not very common, although it does happen, that the clutches wear out. usually it is a solenoid issue or a breakage in the transmission. What car do you speak of?
Old 03-27-2008, 11:24 AM
Maxo's Avatar
Maxo Maxo is offline
I replaced my plates when my duty solenoid c went out on my '92.
6 31588AA060 PT070399 TRANSFER PL $11.29 $67.74
1 31942AA090 VALVE AY TRANSFER CL $78.87 $78.87
2 31954AA071 GASKET TRANSFER VALV $1.16 $2.32
1 31337AA120 GASKET TRANS CASE RE $3.73 $3.73
...From subaruparts.com.
You might expect labor to be at around $200 from an independent shop, double that for a dealership. I was quoted $150 to replace all the parts above but it ended up costing a lot more since my clutch drum was sheared off. I do all my own work now...
Fyi... I believe the transfer plates/part numbers are different depending on the thickness of the first pressure plate.
Old 03-31-2008, 09:40 PM
subarufamily subarufamily is offline
actually all clutches are different I had mine replaced and they had to pull the clutches out and measure to find out which cars part had to be ordered. they then ordered them but svx clutches are NOT around anymore but other subarus are so I have different clutches than SVX 1 is from sti 1 legecy dont remember rest but you get the idea
William
Old 04-01-2008, 08:49 AM
Mr. Pockets's Avatar
Moderator
-Bill
I did it once. It's a relatively scary repair to do on your own. I did it on a Legacy, and I think it cost me about $200 in parts. The clutch pack was the bulk of that, with gaskets and the solenoid taking up the rest.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 04-01-2008, 09:15 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
LevelTen
I believe that Level 10 sells a clutch pack kit that might be worth checking out if you do your own work.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
(+6 with other members of the family)
FREEDOM IS NOT FREE
