Old 10-30-2005, 04:33 PM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
Two installs, problems with one
I finished installing my ECUtune Stage 1v4 today, took a while, but no biggie, I installed it w/out the switch for 87 octane. I can't wait for it to kick in...from what im told it will take 2-3 tanks of gas to work fully?
Anyhow, a few days ago, Chike installed my Smallcar Shift kit, which works fairly well, but I am still getting the power light flashing 16 times upon startup. What could be causing this light, which is of course different from the standard power light blinking 9 times upon disconnecting the resistor. Thanks for any input!
-Andrew
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 10-30-2005, 05:13 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Flashing 16 times just means you have a transmission trouble code stored.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 10-30-2005, 05:29 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Andrew,
I cut the green and yellow wire in your car, which was the same one I cut in mine. As long as that one wire you put a new connector on today is properly hooked up, the shift kit should be functioning properly.
FWIW, several members who install the shift kit still get the 16 flashes of the power light at start up. The new version of shift kit (which you bought) was supposed to have solved this problem, but a few members still get the 16 flashing lights. If you put your trans in '3' and it doesn't lurch when you slow down for a stop light, then the shift kit is working. If the lurching is still there, e-mail Small Car about your issue. You may need to return it for a new one as that unit may be faulty...
-Chike
2006 Steel Gray WRX TR (sold)
Old 10-30-2005, 05:59 PM
I guess that means I'll have to clear it and see what happens....but the battery was disconnected a few times today, wouldn't that clear it?
Old 10-30-2005, 06:29 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
It may not clear it. Just pull the code.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 10-30-2005, 07:02 PM
Yay, more work for the never-ending list JK, its really not that hard. Thanks!
Old 10-30-2005, 08:13 PM
AFBeefcake's Avatar
AFBeefcake AFBeefcake is offline
Subaru Swapper
Send a message via AIM to AFBeefcake
Do a search under my name for the fix. I got one of the first shift kits and had to make up a resistor to stop the power light from blinking, but it will only work on the three pin switches.
I have not seen one of the new kits so this mite not help you.
2005 Legacy GT
2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles
My WRX's Cardomain Page
Old 10-30-2005, 10:44 PM
Originally Posted by Chiketkd
Andrew,
It doesn't matter which wire you cut. What does matter is which end of the wire is connected to the resistor that is in the Shift kit, when it opens.
Green/Red wire------dropping resistor-------kit resistor------switch contacts-----Green/Yellow wire---A solenoid
This will run the Green/Red wire to ground through the kit resistor, and all will be well.
But if it is connected;
Green/Red wire ----dropping resistor-----switch contacts----kit resistor----- Green/Yellow wire----A solenoid.
In this hookup, when the kit switch opens, the dropping resistor line is open circuit, and the A solenoid is connected to ground through the kit resistor. This will bring on the light, as the TCU detects the open.
Old 11-10-2005, 11:32 AM
I feel so stupid that made no sense to me. Chike, as to what you said, the problem still exists where it gear "hunts" on deceleration, so its basically not working at all I might put another connector on it and cover in it dieelectric grease to ensure a good contact?
Old 11-19-2005, 01:35 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Sorry to resurrect a prehistoric thread, but I interpret your remark correctly, I don't have to cut any wires, I just have to reverse the connections to the smallcar shift kit. Pull the two connectors off the kit and revverse them Correct?
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 11-19-2005, 11:07 PM
This remark was made originally by oab_au in this thread.
http://www.subaru-svx.net/forum/show...e+open+circuit
It makes sense to me, but maybe he can clarify it better.
