Old 03-31-2003, 07:58 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Question Instrument panel trim questions
Hey guys. I was working on taking off the trim around my instrument panel and I removed the dummy button next to the security button, but it slipped out of my hand and I dropped it, where it then rolled into the gap between the steering wheel and bottom dashboard where the suede is, where I never saw it again.
Does anyone know how to open the bottom of the dashboard where the suede is? It's killing me that I can't figure out how to open it. I only saw one screw at the bottom but it only loosened it a little.
Also, I'm having trouble putting the instrument panel trim back (with the clock). it seems to get stuck in the right side where the clock and the vent are. Is there a trick to putting it back on?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-31-2003, 09:35 PM
Chicane Chicane is offline
Anti-BS Vigilante
Send a message via ICQ to Chicane Send a message via AIM to Chicane
You know what this means? It's a sign from the lord that thy must install a real switch where the dummy one was. :P
seriously, I'd say its a good excuse to add another 'feature' to your SVX.
- Ca$h
Old 03-31-2003, 11:20 PM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
There isn't anything about taking the instrument panel apart that Lwin (Seraph) doesn't know.
If he doesn't respond, you might email or PM him.
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 04-01-2003, 09:05 PM
floatingkiwi's Avatar
floatingkiwi floatingkiwi is offline
A flight-less flyer
Send a message via Yahoo to floatingkiwi
To remove trim..
Take out that little plastic screw at the bottom, it's one of those "spread and retain"" type of jobbies.
Remove connector to the bulb that lights your feet up and the summer/winter wiper switch.
Prise out mirror control and park/mirror heater switch and disconnect both. Under one of those is the only bolt that secures the trim on.
Now, even though you've got that bolt out, there are two plastic retainer tabs one each side of the steering column. With a little luck you can pull on the trim and it'll pop, but I had to get my finger in behind them to pop them out.
You can remove the steering column plastic to make this alot easier (but that is a PITA as well)....
If you need any more particulars, PM me.
Cheers
Old 04-02-2003, 09:00 PM
Earthworm's Avatar
Meow!
If you are referring to the panel with the change holder/OBD-II plug (depending on year) there's 2 bolts holding it in.
one is behind the change holder and the other is behind the mirror switch/fog light switches. All of those should pry out (carefully). The panel itself is also clipped in but should pop off once the 2 bolts are removed.
Old 04-03-2003, 01:37 AM
I think Lwin has a "How To" in his locker on the removal of the dash. You might check there.
Old 01-03-2005, 09:06 PM
RobSVX
Removing Heater Control ?
Anyone ever pulled this out ? Mine has a few burnt out bulbs and would like to replace them. I've got the bulbs from RS, but not sure how to get at them. It appears they install from behind the unit.
