Old 07-21-2003, 03:54 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Originally posted by svxistentialist
Kuoh's solution is likely to be the correct one.
Happened to mine when I got the car first. Had to strip the column down to get everything tightened up before the ignition would operate every time.
I second that. I had the exact same problem.
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 07-21-2003, 03:58 PM
JacciMullineaux
I was wondering if any of you have had any problems with your check engine lights comming on, mine on my 92 is always going on and off i think there maybe something wrong but when i take it in they say it's nothing. what could this be?
Old 07-22-2003, 12:59 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: ?
First of all, run the self diagnostic to see what code it gives you. More than likely it'll turn out to be an O2 sensor.
Randy Johnson
Mike Davis -- at Reading VI
Old 07-22-2003, 01:07 PM
scottsubarus's Avatar
scottsubarus scottsubarus is offline
Scottsubarus
NO check engine lights at all. Son checked the security bolts on the steering column....they were fine. It did act up again. I just held the key in the "start" position and after a second or 2 it started.
Old 07-22-2003, 07:35 PM
Subafreak's Avatar
Superbeast
When you say you held it there do you mean cranking it over or was it just like a delay befor the starter would spin? If its the delay I'm having the same prob, and really must find out why.
Old 07-22-2003, 08:52 PM
Scottsubarus
I turned the key to the start pos. no noise no crank nothing. I then tried again...nothing except I just held the key in the start pos and after a few seconds it cranked and started. I just was trying to move the car so my son could replace the timing belt and check those bolts in the steering column (they were tight) so back to the drawing board!
Scott
Omaha
Old 07-22-2003, 09:31 PM
kuoh kuoh is offline
A broken timing belt wouldn't cause a no crank situation. How did he check the bolts, just try and wiggle the ignition? You have to remove the upper and lower steering column covers and that requires removal of the lower dash cover, so it isn't exactly a quick and easy job to check.
Kuoh
Old 07-23-2003, 01:32 PM
Scottsubarus
LOL, I know a broken timing belt wont cause the cond. He was planning on replacing it anyway, but had to wait untill the belt that was special ordered came in.
Old 07-23-2003, 06:01 PM
Subafreak's Avatar
Superbeast
Ya it's like a sticking relay or something, If I ever get a chance to check it out when its doing it, I might be able to find out why.
Old 07-23-2003, 07:02 PM
nordique14's Avatar
nordique14 nordique14 is offline
Who watches the watchmen?
I had the same symptoms. The dealership told me it was the battery cables. Ordered new cables and +ve terminal connector. No change. not wanting to spend anymore money, I just lived with the problem.
Then I saw this thread and noticed Aredubjay's post where he mentioned that if he turned the headlights off, it sometimes helped the startup. A little lightbulb went off in my head (and then quickly burned out ). I drive with the headlights on too, so I figured I would try some experiments. As I turned off each accessory (fan, radio, radar detector, headlights, etc) it started easier. This led me to believe that the problem was with the wiring that just new battery cables coudn't help.
After some searching, I found this post. It describes a wiring upgrade that is easy to do. I went to Home depot and spent about $8 on wire and connectors. Only needed a good wire cutter, vice grips, 10mm socket and 14mm socket. Spent less than a hour installing them. It's been two days now and the car has started everytime on the first try. Hasn't done that in months. There's probably an underlying problem I'm not dealing with, but this works so I can live with it.
So if you have the starting problem and it gets better if you turn off the accessories, you might want to try the wiring upgrade. It's easy and it fixed my problem.
Cheers,
