Old 03-08-2021, 11:01 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Rear window wiper interior shroud.
Does anyone have a spare tan interior rear window wiper shroud? The shroud on my '95 Brilliant Red is much the worse for wear.
Old 03-08-2021, 01:30 PM
irox irox is offline
Re: Rear window wiper interior shroud.
Mine is looking in similar condition... but grey and falling to bits.
At some point I'll take my rear shelf off, install some new speakers and fix up the carpet/cover. I might take a shot a designing a replacement, but would have to figure out some heat resistant plastic to make it in, I'm sure PLA would quickly deform as it's hot on that shelf. Possible shapeways could print one in nylon, which could painted to match the interior.
Good luck, let me know if you find a grey one.
Cheers,
Ian.
Old 03-08-2021, 01:33 PM
Will do, although it's been suggested that I get one of whatever color and paint it. If that works, you can have the second one I find.
Old 03-08-2021, 04:13 PM
If it helps, the Beige one is part number: 86538PA000DO
And the grey one is: 86538PA000VG
Subarupartsdeals.com might have a Beige one in stock:
https://www.subarupartsdeal.com/part...38pa000do.html
(They don't have any of the grey ones for sale, so many be you are in luck)
Cheers,
Ian.
Old 03-09-2021, 03:22 AM
On mine the release levers and covers for folding the back seat down are looking nasty. Faded and beginning to crack.
Nearly all rear seat parts are discontinued including these.
Old 03-09-2021, 01:10 PM
Ordered from Subaruparts. Thanks irox
Old 03-09-2021, 01:33 PM
Was just notified that order was canceled because item was unavailable.
Old 03-09-2021, 02:36 PM
Ah, sorry they are out, I had that with something else from them recently as well...
jauce.com might have them occasionally.
