ECU tune Stage 1
Please let me know if the Stage 1 chip Motersport Warehouse sent me will change my SVX to 87 octane usage? I can't get my PC to connect with ECUtune for this info...???
THANKS!
It will support both 87 and 91 provided you wire in a switch to alternate between the 2.
87....or ...91 ...octane
Please give me any info you have about whether this is a good mod....in other words..Is there any negative consequences to me adding that switch and using 87 octane? [I've never complained about Premium prices until recently!!!....HA!
THANKS!....again!
You should be fine. LAN's chip alters the ECU map to allow you to use 87 without running into spark knock. -Bill
