Old 10-16-2006, 10:01 AM
Bxsvx Bxsvx is offline
How fast is fast?
Send a message via AIM to Bxsvx
steering o ring question
would a o ring problem cause sudden pump failure? and then come back on?
Old 10-16-2006, 10:43 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
possibly if you're low on fluid.. It's a $1.00 fix and 20 minutes of your time so it's worth a shot.
Brian
Old 10-16-2006, 11:04 AM
Instructions for changing the O-ring are here:
http://www.subaru-svx.net/photos/files/How-To/14304.pdf
Aways check the How-To Documents link at the top right of the page for valuable information concerning maintenance and repairs.
Old 10-16-2006, 09:45 PM
A bad O ring can cause leaking, and air leaking into the system. The first thing I would do is change the O ring and then if there are still problems, we can figure it out from there. Good luck.
Old 10-17-2006, 02:55 PM
cbx-man cbx-man is offline
There also a fuse in the fuse panel(by the driver's feet) that controls the power steering. I was piggy-backing my trans temp gauge into one of those fuses and shut down the P/S until I made a good connection.
Just another avenue to explore...
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 10-17-2006, 07:51 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
no... did the pump fail or did the system?
- John
Old 10-19-2006, 05:10 PM
How fast is fast?
I strongly feel it was the pump, because I compared the steering with a pump installed and without it, with the pump on I have like 5 percent assist, without the pump installed it felt like the steering wouldnt move, thats how it felt a couple of days ago, but now it seems normal. I put a direct wire from the steering fuse the the steering computer. so i dont think its the system
