Poor gas mileage.
Hi guys. My '97 with 85K on it gets 17 MPG on the same commute that my '96 used to get 21 MPG on. The car runs great and the CEL is not on. Does anyone have any suggestions on how to go about investigating a problem like this? Any help is appreciated.
Chip. |
Re: Poor gas mileage.
Check to make sure you don't have a sticky caliper. I got around 21 with mine until one of the calipers slowly started sticking. I watched the mileage drop to 17 over about 4 months before I realized what the problem was.
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 |
I get nearly 14 MPG in my 92 pearly.. Its terrible.
In 100% commuter mode, I've found 17-19 MPG is about the best either of mine has to give. dcb |
Thanks for the help. It runs so well that I think I will check the calipers first.
Chip. |
I cosider 17 in town pretty good. Of course what you call in town and what call in town can be two different things ( 6 traffic lights a mile or down town NY city or a rural town in Kansas ) I shift 21 times going to work and it is just under 2 miles.
Check the fuel delivery system too.
For example, if you've got a fuel pressure regulator on its way out (rubber diaphram perishing), it could be wasting fuel through that. |
Could that cause a lot of gurgling noises when the car is first started? How does one check the FPR?
