Old 09-22-2006, 05:17 AM
gsodonis's Avatar
gsodonis gsodonis is offline
Clutch & Flywheel question
This is clutch related, so I don't think its a total thread highjack. I have a stock WRX flywheel in my 5SP, but when it tcomes time to replace my clutch, I'd like to buy a lighter flywheel. Any of you manual trannied SVX owners running something other than a stock Legacy or WRX flywheel, please share your stories on pros and cons on going with a light flywheel. I don't race my SVX, so I will probably use a stock organic clutch & pressure plate set up, but I wouldn't mind shaving a few pounds off the flywheel. Recommendations?
Old 09-22-2006, 07:42 AM
unless your flywheel is cracked, keep your stock one. They don't do all that much and it is not worth the extra couple hundered dollars
Old 09-22-2006, 08:16 AM
AFBeefcake's Avatar
Subaru Swapper
I got all the core parts off ebay so my car can stay in one peace until I get all of the parts ready to go.
So just tell me when and I can send them to you.
I got
svx torque bar
svx AT trany cross member
wrx pedal box
wrx shifter linkage
svx brake pedal bracket
svx gas pedal
svx brake booster (but I think I can re thread that)
and once my car is done I'll have another set of cores to sell.
2005 Legacy GT
My WRX's Cardomain Page
Old 09-22-2006, 12:27 PM
Ok, sounds like you have most of what you need. When you get he tranny post pictures in this thread and I will be able to let you now if you have everything.
Old 09-22-2006, 01:42 PM
AFBeefcake's Avatar
Subaru Swapper
I think all I still need is.
WRX master clutch
clutch hose.
A WRX clutch
trany mount
MT starter
bolts(flywheel and others)
replacement exhaust gaskets
Clutch switch
2005 Legacy GT
Old 09-22-2006, 01:48 PM
ah yes.. but sometimes not all of the shift linkage pieces are there and people like to take pieces off of the clutch fork. I have had to pick up a couple pieces like this for shotgunslade's trans and Mikecg's 6mt... Pain in the butt when you are knuckle deep and realize... **** I don't have what I need
Old 09-22-2006, 02:01 PM
WRX master clutch
clutch hose.
A WRX clutch
trany mount
MT starter
Clutch switch
I have:
- WRX master clutch
- clutch hose
- trany mount
So if you can't get these elsewhere let me know.
Old 09-22-2006, 04:32 PM
AFBeefcake's Avatar
Subaru Swapper
Ya, I know what you mean. I was looking for little parts for weeks when I did the WRX motor and drive train swap on my friends legacy.
I'll see what I got on Sunday.
2005 Legacy GT
Old 09-28-2006, 05:22 PM
AFBeefcake's Avatar
Subaru Swapper
I got the transmission. Its missing all of the parts for the clutch fork and pivot as well as the dip stick. I got most of the parts coming. I hope to crack the transmission open this week end and see wants up with it.
2005 Legacy GT
Old 09-28-2006, 05:28 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Good luck with the swap! I know how much time and extra $$ it can take up.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 09-28-2006, 09:04 PM
pictures say a thousand words
Old 09-29-2006, 07:57 AM
AFBeefcake's Avatar
Subaru Swapper
I'll try to get some tonight when I am back at home.
2005 Legacy GT
Old 09-29-2006, 06:49 PM
AFBeefcake's Avatar
Subaru Swapper
Here is a pic of the trany I got.
and the inside
2005 Legacy GT
Old 09-29-2006, 09:04 PM
so are you going back to a stock gearset?? unless you are planning on dishing out some punishment to the tranny I would. Simple enough fix though. Problem is, those clutch fork parts are probobly gonna run you a little bit
Old 09-30-2006, 07:32 AM
AFBeefcake's Avatar
Subaru Swapper
Yes, I am going to just replace the broken gears. I found most of the fork parts on NASIOC for about $30.
It looks like this trany has been opended before. How do I know if the gears in there are the stock gears?
2005 Legacy GT
