Old 03-24-2010, 08:47 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
car wont start...someone please help
Ok so ive always had the click click start problem...around 3 days ago i replaced the relay switch and it cured the problem 90% of the time....well today My car wouldnt start at all. There were no clicking issues....the starter was getting power and turning over. My car was acting like it was 100% out of gas when it had a full tank. I tested the fuel pump-which was fine....fuel filter also fine. What am i missing here? is there something that controls the coil packs that could suddenly short or go out. There is not any studdering at all...almost like there is no firing whatsoever.
[SIGPIC][/SIGPIC]
STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit.
Old 03-24-2010, 08:54 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
Re: car wont start...someone please help
There's this bull**** plastic piece by (it's not part of it, but it's RIGHT THERE) the ignition cylinder that wears out over time that causes this. Anyone know what I'm talking about. I fixed one on another SVX when I first started working as a mechanic a while back.
That, or make sure your security button isn't active :P
Old 03-25-2010, 05:39 AM
dcarrb dcarrb is offline
So you still get the "click click" business 10% of the time?
Turning over but not firing is probably unrelated. Have you tired holding the accelerator pedal to the floor while turning the key?
dcb
Old 03-25-2010, 12:41 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: car wont start...someone please help
When turning key to "on" position are your fans on ALL the time (even when cold?) = ERROR CODE 21
ATF temperature sensor in the transmission is shot - I know I had to change mine (NZ$41.00).
This causes the engine to "lean" out the fuel mixture - thinking engine is really hot!! (hence will not start).
SEE POST 11
Old 03-25-2010, 06:07 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Unfortunately cranks-no start can be a pain to diag.
One shortcut is to spray some starting fluid thru one of your vacuum ports, and immediately try cranking over. If it wants to start then, you verified spark, and if it starts up then dies, you have properly timed spark... and can focus on the fuel system as a cause.
If it has no effect at all, then I would look at the ignition system or air/temp metering.
Try the starting fluid thing and also check for any codes, then report back and we can take the next step.
Old 03-25-2010, 08:10 PM
NiftySVX NiftySVX is offline
I am thinking you meant ECT sensor in the crossover pipe, It is easy to replace and a common failure especially if you haven't been good about changing your coolant. The ATF temperature sensor does not even go to the ECU in this vehicle
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 03-25-2010, 08:21 PM
SURTEESS's Avatar
No I ment what I stated initially ATF Temperature sensor is bad (thermister gone open circuit) ERROR CODE 21 = lean fuel mixture (fans on all the time), which makes car near impossible to start (except with foot flat to floor). trust me I had Subaru change that this week with mine......any one else want to back me up.....
SEE POST 11
Old 03-25-2010, 08:37 PM
The Automatic Transmission Fluid temperature sensor is inside the transmission pan and monitors the temperature of the automatic transmission fluid. There absolutely no communication to the engine control unit on this circuit, It is used by the TCU only. You are thinking of the ECT sensor. there is no fail code that the ECM will output to display a failed ATFT sensor, for the reasons stated above.
Code 21, furthermore, is for the ECT sensor.
Old 03-25-2010, 10:59 PM
Trevor's Avatar
Trevor Trevor is offline
Reverting to the original subject.
You must logically suspect something involved with replacing the relay is a possible cause of the problem. Could you have disturbed some associated connection or wiring? Everything associated with the ignition switch must be suspect.
Does everything which should come on when the switch is on, do so without any problems and for 100 % of the time.?
Trevor, New Zealand.
Old 03-26-2010, 01:32 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Im sitting here wondering if the OP tried the starting fluid, and realized he hasnt responded to anything yet.
Before tinkering around with electronics or wiring, i would definitely use the starting fluid so you can eliminate or confirm properly timed spark. Then you can go the right direction from the get-go.
Old 04-03-2010, 01:48 PM
jman050's Avatar
Its a Classic!
thanks for the help from everyone and sorry for my inconsiderate time period in between posts. Been working 60 hours a week and really hard to get much of a look at my car. Anyway the fuel pump is fine, fuel filter is fine, MAF is fine, crank position sensor is fine, timing belt is lined up correctly, the relays seem to be fine as the starter is getting power but still no plug firing. The fuses are all fine. And NO codes whatsoever. Is there anything im missing???
[SIGPIC][/SIGPIC]
Old 04-03-2010, 02:02 PM
Hold on for just a second, but what is this relay click thing? I've been having starting issues with the click and having to turn the key back and forth rapidly to start.
Nevermind.
http://www.subaru-svx.net/forum/show...tarting+issues
Old 04-05-2010, 06:11 AM
sowise sowise is offline
I did a quick check but didn't find a test procedure for this part though you could do some poking for voltages and continuity. If you are getting no spark I would think it could be the ignitor. (see pic). There is a small chance I may have a spare you could use to see if it would work.
Old 04-05-2010, 01:21 PM
Trevor's Avatar
A very good possibility has been pointed out above.
The igniter is basically a quite simple device and comprises what amounts to six solid state relays, assembled within a single package. These relays are necessary, because the ECU is not capable of switching the relatively high currents, involved in supplying the low voltage required to trigger the on-plug ignition coils.
Each solid state relay is switched via a positive signal from the TCU and it would be possible to test the igniter by applying voltage to the input terminals and then checking the outputs. Precaution and understanding would be required.
With the igniter in place, it should be possible to confirm a pulse at each of the outputs to the coils. N.B. The output circuits ground the ignition coils and therefore the negative supply to the coils.
There has been mention of faults occurring in the positive supply to the coils. It appears that there is a concealed connection within the loom which supplies the left and right hand banks. There should be a constant positive supply to all coils when the ignition switch is on.
P.S. On checking back through the thread, it would appear that you have not confirmed that you have sparks.
Old 04-09-2010, 01:06 AM
jman050's Avatar
Its a Classic!
I may have to take you up on that offer. I have to talk with my mechanic. Last he told me he was trying to find the ignitor box for a spare in the junkyard, but im assuming he was unsuccessful. If he has not found one yet and he has one i would even be willing to put a down payment on the thing so u know i wont run away lol.
[SIGPIC][/SIGPIC]
