Old 03-04-2006, 12:30 PM
keithwrx8's Avatar
keithwrx8 keithwrx8 is offline
Send a message via AIM to keithwrx8
new here
Hi guys, im currently and owner of a 2004 wrx, my dad just bought a SVX which had a manual transmission swap from a legacy i believe, ill have to double check on the tranny, ive read a bit on them about how the A/T were very sluggish and bound to break and some of the rear bearings go bad, its a 1992 which im guessing is the worse year for them since it was the first, kinda like the 02 wrxs, so anyways i was just wondering what my dad is gonna be expecting to go wrong with the car, the engine has 40,000 miles on it and the chasis has around 72,000 i believe. thanks in advance
Old 03-04-2006, 02:46 PM
Welcome to the site. Your dad is going to enjoy his car very much. It is not as bad as whay you say about these cars. Maintenance is the main thing that should be done and kept up to date. If he has a 5 speed, there should not be all that much that he will have to do.
Old 03-04-2006, 04:09 PM
It's Just Eric's Avatar
Missing in action
Welcome to the forums.With that fresh of a motor and chassis...there shouldnt be much wrong with it, Keep it maintained and it should keep going good. you may want to go over the 5 speed install the previous owner did just to make sure nothing was done poorly. Even simple stuff like the design of the crossmember and shift linkage add to how well the car drives.As far as all the other stuff, try searching for common matinence issues and things to look out for.
Just curious, did he buy the car from a member here?
I hope your dad has good luck with the car
R.I.P Cool Signature.
Old 03-04-2006, 04:31 PM
Sounds like the Liquid Silver 5 speed that just sold on Ebay, is that the one? I had been watching it.
Old 03-04-2006, 05:12 PM
keithwrx8's Avatar
yup thats the one
as far as the tranny install, the guy was a subaru tech so im thinking he knew what he was doing, it has the wrx linkage and the kartboy short shifter, but ill look over all of that to make sure everything is clean
ive always liked the SVX, so im pretty excited myself for him to get it, ive always wanted to drive one
thanks for the input guys
Old 03-04-2006, 06:35 PM
That car's location was listed as Conshohocken Pennsylvania, is it going back to Michigan or is your Dad in the area? (Just curious.) I hope he likes it, from what the auction described it seemed like it needed a little bit of work, but for a SVX with the 5 speed conversion already done, I think it was a great price. Good Luck with it.
As far as the trouble areas, the rear wheel bearings tend go bad. The Rotors can warp with heavy braking. The radiators tend to crack on the top tank. The Automatic Transmissions die (but that won't be an issue on that car ). Many of the other members can tell you more, I'm fairly new.
