Old 07-18-2012, 02:16 PM
The Molinator
Question Head Gaskets + REBUILD???
It appears I may (OK.. I DO!) .. need head gaskets??
If I do them.. shouldn't I seriously consider rebuilding or replacing with rebuilt engine!? I have 236K miles on my 1995 SVX .. .
If so.. Are there any good sources here? For rebuilding info.. parts/guidance .. OR probably better yet.. REBUILT ENGINE?
Thanks, Jim
Jim
Old 07-18-2012, 03:11 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Head Gaskets + REBUILD???
I don't know about the USA, but in my country, the cost of that repair is considerably more than the cost of another SVX. So it would make more sense to buy a better SVX and keep your current one for spares.
If you have the time and tools and skill to do all the work yourself then maybe it's worthwhile.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
