Old 07-05-2012, 01:20 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Atf fluid
What to use? Putting a new used transmission in and want to flush it.... But should I use to replace the old oil?
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 07-05-2012, 01:35 PM
Huskymaniac's Avatar
Uses the ignore feature
Re: Atf fluid
How many miles on it and how well was it maintained? If the miles are low or it was maintained well, use Redline D4. If it is questionable, use Subaru ATF with a bottle of Lubegard ATF Protectant.
Tony
Old 07-05-2012, 02:09 PM
VICSVX's Avatar
Never Forget
Re: Atf fluid
The car has 140xxx and not sure if it's the original transmission. The car was in good shape till it was hit front pass corner. The transmission seems too work fine but lags after putting it in gear (low fluid I suspect)
VICSVX
Old 07-05-2012, 03:27 PM
Re: Atf fluid
+1 on the Redline D4. I also like the Redline high temperature ATF.
I am assuming, since you live in AZ, that you have a tranny cooler to keep those temps down.
Old 07-08-2012, 11:13 AM
VICSVX's Avatar
Never Forget
Thumbs down Re: Atf fluid
Yes I have a transporte cooler
VICSVX
