Old 03-30-2017, 10:42 AM
drivers side engine mount
hi all, looking for a drivers side engine mount. subaru parts dept indicates it is no longer available
Old 03-31-2017, 01:04 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Re: drivers side engine mount
Yes that is correct the mount (41022PA010) and bracket (41031PA110) for the left side are NLA.
The best solution is to use the Group N Engine mounts which are meant for the 2002-20015 WRX STI. The mounting plate will require and additional 1/4'' plate and grinding off some material to have the engine sit at the correct height.
Group N Engine Mounts:
Eng Mount F Left-Hand
Part Number: D1010FE120
Eng Mount F Right-Hand
Part Number: D1010FE110
If you want these, I can get you a much better deal than your dealership will.
-Sam
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
