Old 10-22-2012, 06:50 PM
oab_au oab_au is offline
Re: Some Troubleshooting help please
Originally Posted by Uncamitzi View Post
Holy Cascading failures Batman.....
Car started...I went to clear and check the codes....
Now I have CEL #s
34 EGR Solenoid Valve; EGR Solenoid valve inoperative (as before)
29 Crank angle sensor 2; no signal from sensor 2 but two signals from crank angle sensor 1
23 Air Flow sensor; Abnormal voltage from air flow sensor
13 Cam Angle sensor; No signal from cam angle sensor but signal from crank angle sensor1
Interesting development. I've now lost the crank sensor..... (code 11) also recurring Cam angle sensor (code 13) making me wonder if it's an age thing with the magnets in them. At any rate, the car won't start. And I guess I'll be ordering new ones rather than try to swap them with wrecking yard parts. Also still throwing the EGR solenoid code (34) I can't imagine that's causing a major problem...but then what the F*** do I know ...
I'll be back when the sensors get here....
These are not easy to check, you have checked the continuity, so the windings must be intact. The output should be checked with an oscilloscope to see the waveform, but the book says to check them by waving a magnet across it and checking the output on a AC scale looking for about 0.1V.
This really only checks the windings, but not the strength of the magnetic field of the sensor, so I would check it while turning the engine over, looking for about 0.1V.
The common factor between the cam and crank sensor 2 is the ground wiring, as they both have the grounds connected together, going to the ECU. Maybe a ground problem, check the continuity of the ground wiring back to the ECU. Check the ground on the rear of the engine.
One Arm Bloke.
Tell it like it is!
