Old 07-21-2012, 04:42 PM
torxxx torxxx is offline
blew a PS pump, what will interchange?
Well the impellor in my PS pump decided to wear all the way or out something. Steering started acting weird, its heavy and then easy heavy than easy. Needless to say, I grabbed a spare pump off my 95, and I guess it was blown too (never drove the 95, so it was a chance that it might have been good lol)
Will any of the EJ Power steering pumps work on the SVX? I could give 2 shats about the speed sensitive part, I just need the car to drive and not kill my shoulders while doing it.
I've got access to a 01 Forester, 99 Outback and a few 90's EJ22's. Thoughts?
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car
86 Lifted GL wagon well over 600k miles on the chassis
98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires
Old 07-21-2012, 05:26 PM
Stevebsy's Avatar
Stevebsy Stevebsy is online now
Administrator
Re: blew a PS pump, what will interchange?
Did you check your crank pulley? It may be separated which is why both pumps don't work.
Good luck!
'20 Honda Ridgeline
http://www.x35design.com
Old 07-21-2012, 07:19 PM
Have you checked the O ring in the fluid tank? It sounds like that could be the problem. I would do that before anything else. I would do it even if you have replaced it in the last several months.
Old 07-21-2012, 08:37 PM
Green1995SVX's Avatar
To answer your question: No other pump will fit directly onto an SVX. It must be from another SVX. Year doesn't matter. The speed sensitive part is external to the pump, so that doesn't matter either.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 07-21-2012, 09:20 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Why don't you rebuild it? Check the 'how to' section. I did it, it wasn't hard and the parts are inexpensive.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 07-21-2012, 09:41 PM
I just ordered a reman'd pump. I dont have the time to sit and tear down a pump and wait for parts. priority mail, it'll be here in 5 days.
The O ring is fine, I just replaced it within the last 6 months. My old pump has had a bent shaft since I got the car, and its always leaked a lil bit of fluid. I'm going to go put it back on right now, so i can at least use the car.
Thanks for the info
