Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Turbo Projects
Old 01-31-2006, 03:26 PM
svxsubaru1's Avatar
svxsubaru1 svxsubaru1 is offline
Why not use water/alc/meth injection?
Since the SVX has a 10.1 to 1 comp ratio it seems like using some sort of injection system using water/alc/meth/propane would be greatly benifical in letting us run alot more boost while still using the stock internals. I know you still need to be able to mess with fuel supply and boost to aculy get any benifits, but it seems like emanage could let us adjust enough to get some pretty large benifits from it. Any opinons?
Here are some links on genral information on it, and evn DYI kit for under $200.
http://www.rbracing-rsr.com/waterinjection.html
http://www.turbofast.com.au/racefuel.html
http://www.buickgn.com/alcoholinjectionsystem.htm
http://members.cox.net/stevemonroe/AlcoholInjMod.html
http://www.importpoweronline.com/propanecontent.html
92 Honda CBR 600
95 Miata
Old 01-31-2006, 04:47 PM
mbtoloczko's Avatar
sans SVX
I've been suggesting this for the last couple years, and back when I was planning to build a turbo EG33, I was planning on using water injection instead of an IC. For mild boost levels, it could easily work in place of an IC. Seems that the most common arguments against it are, "what if it breaks", or "what if I forget to put water in", or "its a hassle to always have to add water".
Mychailo
Visit my locker
Old 01-31-2006, 08:55 PM
svxsubaru1's Avatar
I think it could do more than that, theres STi putting out 500 WHP on pump 93 with meth injection. I bet we could get the eg33 to handle +10 PSI on pump if we could get the fuel (injectors/pump)for it with a safe tune with alc/water mix.
92 Honda CBR 600
95 Miata
Old 02-01-2006, 06:43 AM
LiquidForce LiquidForce is offline
Send a message via MSN to LiquidForce
I have been running the SMC kit on my WRX for almost year now. I picked up 40whp and 60tq from being able to push the boost up and pulling out some fuel. If your crazy like me you may even try adding Nitro to the mix.
If you are going to get one I would suggest getting one with a progressive MAP based controller.
Old 02-01-2006, 08:23 AM
mbtoloczko's Avatar
sans SVX
Originally Posted by LiquidForce
I have been running the SMC kit on my WRX for almost year now. I picked up 40whp and 60tq from being able to push the boost up and pulling out some fuel....
Yep, that's exactly what I would expect... A little less fuel to get more to the optimum power afr and better detonation control. Makes me want to reconsider spending the money to turbo my EG33. :-)
Mychailo
Visit my locker
Old 02-26-2006, 12:05 AM
VTsuby
I have a friend with a pickup thats about 10:1 with blower and water injection thing is a 2.25ton weapon. Don't forget the fuel economy benifits of injecting water
Old 03-02-2006, 11:28 AM
sicksubie's Avatar
SO.... Go for it mbtoloczko, we have already had one success story this week. Start working on another one.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 03-05-2006, 08:54 PM
svxsubaru1's Avatar
How much of an improvment did your friend get for MPG?
Any one have experiance with this?
http://www.urdusa.com/product_info.p...s_id=120000037
92 Honda CBR 600
95 Miata
Old 03-06-2006, 03:09 AM
Pure_Insanity8's Avatar
Pure_Insanity8 Pure_Insanity8 is offline
Send a message via ICQ to Pure_Insanity8 Send a message via AIM to Pure_Insanity8
SVXtasy used an AIC in his turbo setup... that part of his setup seemed to work pretty well.
-Aaron
SVX: '92 Dark Teal 101k
'97 Legacy GT Wagon: dead
'99 Civic Si: daily driver... stolen and stripped with all my tools!
'92 Yamaha FZR 600: garage
2011 Jetta: Daily disappointment
Old 03-13-2006, 05:45 PM
sicksubie's Avatar
What about just mixing in a pint of tuolene and a pint of xylene with a tank of gas? I got the idea from Gads he told me to go to a paint store and you can get a 10 gallon container of each. I don't remember what exact octane ended up being but I think that it was around 99. The only thing is that one of the chemicals is for cleaning your valves and the other is the actual octane booster. I gotta get a hold of him and find out which was which.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 03-13-2006, 06:10 PM
Phast SVX's Avatar
Phast SVX Phast SVX is offline
BOOOOOOOOOOOOOOOOOST
Send a message via AIM to Phast SVX
he is no longer using the AIC,
phil
~Phil
Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog.
Old 03-13-2006, 11:28 PM
mbtoloczko's Avatar
sans SVX
Methanol/water injection work differently than toluene or xylene. Methanol/water are not actually octane boosters. Their purpose is to cool the combustion chamber and slow the burn of the fuel. An octane booster will slow the burn but will not cool the combustion chamber.
Mychailo
Visit my locker
Old 03-14-2006, 01:06 AM
drivemusicnow's Avatar
drivemusicnow drivemusicnow is offline
Poor College Racer
Send a message via AIM to drivemusicnow
water/alcohol/meth injection is and always will be a good safety or power adder. I've been suggesting it to people as well.
I particularly like the cooling mist controller that is offered.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 03-14-2006, 04:35 PM
sicksubie's Avatar
What is actually involved in adding a set-up like this?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 03-16-2006, 09:23 PM
mbtoloczko's Avatar
sans SVX
Came across an interesting alcohol/water injection kit mentioned on EvoM:
http://www.devilsownonline.com/
For only $290, they have a kit that meters alcohol/water in proportion to the amount of boost. Pretty cool.
Mychailo
Visit my locker
