Rear window wiper
My rear winshield wiper does not park itself at the bottom of the window near the rear trunk lip. It rests about six inches up. The switch under the steering wheel for the winter wiper position is in the summer position. Can this be fixed or do the need to replace the entire wiper motor? Thanks for all of your help.
Michael 1994 Barcelona Red SVX-LSI Two-owner:169K 1995 Emerald Green SVX L AWD #80 - Custom intake w/cone filter 99K with killer stereo system 2002 Acura MDX-Touring Edition w/navigation 2008 Toyota Prius 1987 Mercedes Benz 560SL |
I met a person several weeks ago with the same problem. The rear wiper is easy to fix. Lift up the cap on the arm over the shaft and remove the nut. Pull the wiper arm off and reposition. That will do it. The under dash wiper switch does not work the rear one.
Nice. every now and then mine goes back too far. Didn't think the fix was that easy.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
