Old 09-08-2017, 05:27 PM
Jvan Jvan is offline
knock sensor replacement
My "Check engine light" indicates I need to replace a knock sensor. How many "Knock sensors" does a SVX have?
Old 09-09-2017, 09:31 AM
SVX_MY_BABY's Avatar
Re: knock sensor replacement
Two. The code should tell you which one is bad if I remember correctly.
Edit: 22 = right side, 28 = left side
Peter
Old 09-09-2017, 10:34 AM
Thanks for the info. I didn't pay attention after my mechanic said "knock sensor" so I don't know if he told me which side. I found a site on ebay which sells them for under $6 including shipping (not from China but Florida so I don't know about the effect of Irma),so I'll just order 2. Thanks again.
Old 09-10-2017, 08:39 AM
I got mine from Rockauto.
This may help:
http://www.subaru-svx.net/forum/show...t=Knock+sensor
http://www.subaru-svx.net/forum/show...postcount=2631
Peter
Old 09-10-2017, 02:12 PM
I checked Rockauto and their cheapest knock sensor is about $30 while these from FL. are under $6 but I need to check if they are made in China (my guess is YES) but I need to wait until after IRMA destroys FL. to try and contact the seller.The photos are a great help since I didn't know where the knock sensors are located but it looks difficult to reach those sensors, even w/proper tools since I don't have small hands.
Old 09-11-2017, 01:04 PM
bheinen74 bheinen74 is offline
better look up a contortion artist mechanic on craigslist with alien like fingers that is used to working on ufos
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 09-11-2017, 04:56 PM
After looking at those instructional photos, I ask why are the knock sensors so hided; guess the designers aren't mechanics.
Old 09-12-2017, 08:20 AM
To do their job, they have to be on the block to sense the "Knock" in the motor, to keep timing in check....
Old 09-13-2017, 10:49 AM
wdb wdb is offline
dances with roads
I replaced mine. It was a piece of cake! Especially since I already had the intake manifold off...
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 09-14-2017, 11:36 AM
I didn't mean to insult an engine designer but I realize they have to be in the block to do their job. Since I really don't know how they measure knock in all 6 cylinders from the center cylinders on each side, their placement could be in a more convenient location since they will eventually need to be replaced. As far as the replacement knock sensors for < $6, they are from China, not my first choice of manufacturing. I'll check w/Rockauto but they may also be from China.
Old 09-21-2017, 11:00 AM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
If you have to pull the Manifold, then don't make yourself do it twice. Look at replacing the water hose on the right side of the engine top. It is a section about 4 inches long that runs front to back. I had to re-pull to get the hose redone when it blew out shortly after doing both sensors.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 09-21-2017, 03:13 PM
All the vacuum lines too. I'm sure they're brittle.
Old 09-23-2017, 02:13 PM
wdb wdb is offline
dances with roads
Ditto and ditto.
Old 09-24-2017, 08:04 PM
Smile Re: knock sensor replacement
All good recommendations
Old 09-25-2017, 07:56 AM
Hmm. I didn't find it very difficult to just slip in the box wrench & change the sensor without disassembling everything. (Passenger side)
Peter
