Old 05-23-2009, 08:17 AM
svxash's Avatar
svxash svxash is offline
Who's using speed bleeders?
So my front calipers need rebuilding so I'm going to do all 4. It was mentioned in another post to use speed bleeders. Who's using them and where's the best place to get them?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 05-23-2009, 08:37 AM
Re: Who's using speed bleeders?
I used them on a CJ5 and found them to be rather useless. I thought they would be a great addition, but after wards i concluded that they were a waste of money. Too bad as I thought they were a great idea. This is my sole 'hands-on' with them, so others may have differing experiences.
Why not just gravity bleed? This has gone good for me on at least a bill of cars in about every make.
blk 92' LSL w/ average mods
Old 05-23-2009, 09:06 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
I have them on my SVX. I think they are great. They turn the task of bleeding brakes into a 10 minute one-man job. At the race track, that is indispensable. You just start at the farthest caliper, open it up, stick on the hose, pump the brake pedal a couple of times, pull off the hose, tighten it back up again and go to the next caliper. You can do it almost as fast as it takes me to write it. Note that you don't have to keep the brake pedal down after the last pump to avoid drawing new air into the system, which is why normally brake bleeding is a 2 man job. The one-way valve keeps air from entering the open valve.
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 05-23-2009, 10:29 AM
I have them on one of my cars and they are great. +1 with the post above. The only down side I see is the price. If I remember right, they are about $35 a set.
Old 05-23-2009, 10:37 AM
SuberNatural SuberNatural is offline
+1 on that I have russel speed bleeders and they work awesome
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
Old 05-23-2009, 10:55 AM
Here is the link to the speed bleeders. The price has gone down some. Now about $20 per 4 + shipping.
