Closed deck question
What is the difference between closed decks, semi-closed decks, and open decks? Also, what is the estimate amount of boost an EG33 can hold without getting sleeved?
So far the highest I've heard of is 12lbs of non intercooled Supercharger (LANs Stage III)
Decking
How much boost the SVX can take "reliably" is a tough question. I wish I knew the answer to that. I think closed decking would add a degree of reliability. But done improperly could make matters worse. There used to be speculation that the old 2.2 liter needed closed decking for boost levels over 7 psi. Hence the turbos had it stock in the motor, along with oil squirters. I think that is BS though. Look at the 2002 WRX boost levels at around 13 psi. No trouble there. They semi close the deck of the STi. They are running boost up to about 17 psi I think. They also have slightly higher compression, although that is not the case anymore with the 2006 WRXs. But again these are all completely different from the SVX in compression and boost levels. I also think that a good top and bottom grooved piston o-ring and metal gasket would help reduce cylinder walk, without the complicated installation of decking. We shall see how reliable our motors are with all of the additional boost we are throwing at it.
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
No one really knows for sure, but like mikecg said lans running 12 PSI on a completly stock block. I really dought that the open block configuration is going to be any kind of limitation untill you get to the 20+PSI range. There are many people over on nasioc that are pushing the open deck ej205 past 20 PSi with no problems, and there are people pushing 30+PSI(500whp) on stock STi semi closed blocks with no problems(with a good tune). I belive even Gadiel with his 9.6sec1/4 STi is using the stock cylinder liners from the EJ257 and is pushing (i belive) around in the low 40PSI range and (around 750WHP) on a semi closed deck. I really belive that the weaknesses of having a open deck are compley over played by alot of people. Besides I bet if you need to replace cylinderliners, then you will need to have replaced at least the pistons and probably rods before you will be pushing enough boost to oval the cylinder walls.
Cdigerlando the ej22t that was used in the first gen legacy was an closed deck block, and is considered by alot of people to the strongest block subaru ever made.
92 Honda CBR 600 95 Miata Last edited by svxsubaru1; 10-10-2006 at 10:14 PM. |
ej22t
If I can ever figure out how to hack into LAN tunning and start to play, I can tear down my spare EG33 and see what kind of boost the motor will hold with some different pistons. But without being able to tamper with it, I am shooting blanks
Tom |
FI lightened = race car!
That is what I like about having stand alone. Its a pain to set up, but I can do just about anything with it. I will be trying to slam it with as much boost as I can. I'll tell you what though. If LAN was able to make power with the advance he was using at 12.5 psi, I think I'm done with mods if I can achieve this too. Really, a turbo putting out 13 or 14 psi at 10:1 compression and 25* of timing is sick. I don't think I'll be driving my WRX anymore. Tom....I would be very happy with what you have for a while. It is a sweet setup, and a lot easier than the stand alone system. You need to update your installation. I would really like to see what kind of 1/4 mile times you are doing. Could you imagine this car with FI and a 6MT? It would be really sick. Then throw race fuel in on race day, and the race fuel map. It would be unbelievable.
92 Honda CBR 600 95 Miata |
