Car won't start, no wait its not that simple
Ok guys it seems that every time I post something cool it comes at a bad price. I instaled some STI ground wires (they look hott!) however to get to one of the stock grounding points (the tranny) I had to remove the intake pipe (and the MAF) Now the car won't start and I have done everything:
Cheaked the battery, fine Cheaked the fuses, fine Removed the wires and installed the stock ones, nothing jumpstart her, nothing Everything I try seems to lead me to one of two things: a short, or the MAF has an override that I triggered and have not turned off. Please help.
-Chris '94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc. |
Explain the exact symptoms you are getting while turning the ignition to on/start.
You turn the key and....... 'what' happens? What kind of nothing? --- Did you plug your maf back in?
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 03-22-2006 at 05:15 PM. |
Did you hook the ground wires up to the positive battery terminal?
No, I'm sure you would have noticed the bright flash . . . Dan |
Do you have warning lights or interior lights or is everything dead?
Did you check the fusible link in the fuse box under the hood? Do a search for "fusible link" and see if this helps. /
Nothing like nothing, no sound no lights no ding ding ding when I open the door no door panel lights no nothing. I have checked all the fuses but what is this fusable link? All the fuses are fine is that what you mean??
There is a fuse box under the hood. Open it and see if the white rope thing with black insulation at the base of each end is in tact. That is the fuseable link.
If it is broken, only replace it with a new fuseabe link, don't play around with it. Do it with the battery disconnected. I feel like I am forgetting something here...
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? Last edited by Speedklix; 03-23-2006 at 08:11 PM. |
