Trans or rear diff
I'm having a problem with the transmission or rear differential in my SVX. It runs and drives fine but I get a popping or binding noise when I make a tight turn. It's worse when backing up. Driving straight and normal turns, no problem, but if I turn sharply when I take off or backup it sort of pops or grinds. It seems turning to the left is worse than the right. I'm pretty sure it's not the CV joints. I never hear the telltale CV rattle and I never have any noise when driving down the road. I am assuming it is probably in the rear diff but I was hoping someone may know how to tell if its the diff or in the tranny. Can anyone help?
Sounds like the center diff (the transfer clutches) are binding....could be the solinoid that activates the clutches....
Either can be done with the tranny in the car, by removing the rear housing on the tranny.... some people have had good results by adding "LSD additive" to the tranny fluid (yes the stuff for the rear diff)..... Also, make sure all your tires are the same size, brand, and worn the same.... Miss matched tires on an AWD is a big No-NO
Thanks. I have a couple of old transmissions laying around. I'll try the rear clutch assembly from one of those. I hated to remove the rear diff from one of my other cars just to see if that was the problem. I have been having trouble finding one to purchase. That would have been a lot of work.
I am having the exact same problem, and I just resealed my trans and put new frictions/steels in. I didn't replace the selenoids. Thats aboult all I didn't do. Any idea which selenoid I might need to replace?
Duty C solenoid. I dunno exactly which on it is in the tranny, but I'd guess it's the only one in the tailshaft housing.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
Exactly what Paul said...it's located in the tail housing on the tranny...the only one in there...
