Old 11-09-2003, 03:41 PM
Kurt_W Kurt_W is offline
^ has Subaru issues
Send a message via AIM to Kurt_W
XT6 lug pattern?
I was wondering what the lug patterns on a 91 XT6 would be? I have done some looking for the information but so far its resulted in pictures of both 4 and 5 lug XT(6)'s. What I'd like to know is if the lug pattern in 5x100mm (on the 91 XT6.)
Also, are there any glaring issues that one should look out for before purchasing an XT6? The one I'm looking at is quite rough but aside a missing radio, appears to be intact, aside from a general lack of love. I expect to pay about $500 for it if it runs... Looks like it leaks a bit but other then that I can't tell anything from looking at it. (That and the hood won't open.)
Thanks
'04 WRX SW - WR Blue - 26000 mi
'95 SVX L-AWD - Green - 143k
'92 SVX Ls-L - Dark Teal - 67300 mi
'91 Miata - a lot-o-miles
'88 CRX Si/B16 not-so-SiR
'73 Datsun 240Z
Old 11-09-2003, 05:21 PM
The XT6 uses the same stud pattern as all 5 lug pattern as all the Subarus (except the SVX)
I have Turbo Legacy wheels on my XT6
Old 11-09-2003, 06:33 PM
Porter
As Huck said, the XT6 uses 5x100 bolt pattern, +53 or +55 offset stock, I can't remember which. You should be able to use from +45 up depending on the wheel width, some experimentaton will be necessary depending on the tire size and the location of the wheel centerline, which changes with width and offset.
Stock WRX wheels fit perfectly on an XT6...
