ECON Mode
I know that the SVXs have regular and power mode and some of the UK cars have Economy, is it possible to swap in a UK TCU and hook up a switch for that?
How much MPG would you gain in ECON mode?
Re: ECON Mode
I believe the econ mode is only available with the VTD trans. If that's the case, then no it is not possible. I also don't think you'd see a major change in fuel mileage as the stock maps are conservative to make use of the high torque engine.
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
Re: ECON Mode
http://www.subaru-svx.net/forum/show...74&postcount=1
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
Re: ECON Mode
I have looked into the options on foreign markets quite a bit, though my knowledge is old (and therefore, hazy)
I was under the impression that econ mode over their was simply a marketing scheme. That it was the exact same as our power mode, or the power switch (jdm) but in reverse. instead of pressing it for POWER, you were pressing it for NORMAL
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! |
Re: ECON Mode
Phil has got inside the software and mapped all the parameters that are used for each mode. As Need for Speed says most of them control what way the box makes upshifts and down shifts. The UK box has a number of shift patterns. They are Power Normal Econ Manual Cruise. In addition to these there are map routines that work in emergency, such as the Limp Home mode and the Overheat mode. The US did not get Econ mode, but trust me, don't pine for it. It's a lot like sending your car off to the vet to be speyed. An electric wheelchair has more acceleration than the SVX in Econ mode. It really is that bad, you don't want to know. Purely a marketing response to the Oil Crisis at the time. As useful as a chocolate teapot. Joe
Re: ECON Mode
Good one Joe!!! Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
Re: ECON Mode
Press it for Econ mode, release it for Normal mode. Phil has remapped TCU code for these cars, press it, Econ light bulb on gets Normal mode, release it, new Normal mode map is reprogrammed to Power mode. How cool is that?
Re: ECON Mode
Phil tested his MPG Normal mode vs. Power mode, and can't measure the difference, so he leaves his JDM cars in Power mode. Econ allows the car to upshift at lower speed than Normal, given the same amount of throttle. If you want to upshift sooner, use very light throttle. Econ has no effect in top gear, the mode only relates to transmission shift programming.
