Old 04-12-2010, 11:08 PM
smileycaver smileycaver is offline
One more back on the road!
Hi All!!
Its official- One more SVX is now back on the road!!! Finally got my 92 LSI back onto the roadways. Purchased it several months ago dead in the water. But after new brakelines, tires, rims, transmission, valve cover gaskets, power steering lines, trans lines, trans filter, plugs, fuel pump, fuel lines, new crank pulley, main crank timing gear, and shear pin- it is now driving again! Took it on a hundred mile trip today and discovered I'm about halfway done... now to the brake system, suspension system, rear end, and bearings.... Oh, and the sunroof won't close...
But---I LOVE IT!!!!
-smileycaver
If it was easy, the previous owner would have done it...story of my life...
1992 Silver-trying to bring back to life!
Old 04-12-2010, 11:48 PM
K_Dub's Avatar
K_Dub K_Dub is offline
Headin' for the hills
Re: One more back on the road!
Nice work
I'm currently on the path of the man who crosses half of a room, then half the distance from there, then half, and so on. Forever half way there, but never reaching the destination. It sounds like this is one SVX that's found itself in good hands.
'92 LS-L "Bandit" #362 formerly dark teal, repainted by prev owner
Mods: ECUTune 2v7f, Earthworm bushings, Pioneer DVD/Bluetooth phone, Infinity Reference all around, tint, 17" wheels, custom seat belt computer, velcro visor
Buying parts is like car payments. Someday she'll be all mine.
Old 04-12-2010, 11:55 PM
Keep up the good work!
Old 04-13-2010, 12:01 AM
BoxerFanatic's Avatar
Kudos, and carry on!
Great to hear stories of keeping these cars rolling.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 04-13-2010, 12:34 AM
Glad to hear, I just got done putting one back on the road and another just 2 weeks ago.
Enjoy it These are great cars and I will never, not own one
Old 04-13-2010, 07:39 AM
SVX_MY_BABY's Avatar
But---I LOVE IT!!!!
You can manually crank the roof shut. Tool was supplied with new cars and instructions in the owner's manual.
Great to hear of this resurrection.
Peter
Old 04-13-2010, 08:33 AM
Good job on addressing some items and getting the car back together..
You may need to push on either the right or left side of the sunroof as its closing, in order for it to catch. I've had this problem before.
Good luck.
Old 04-13-2010, 12:43 PM
Drove it again today, still running well. BUT- I have to get the shimmy fixed in the front end. Only happens above 60, any suggestions. It also shimmys on hard braking.. Bad bearing???
-smileycaver
Old 04-13-2010, 12:48 PM
Check some of the obvious things first, flat spots on tires, wheels out of balance, brake rotors could be warped causing the "shimmy" when braking.
Old 04-13-2010, 03:12 PM
If the shimmy comes & goes it's probably not wheel balance. That would give you a constant shimmy which will increase with speed.
Check for a bent or slightly dented rim. If you suspect one the shimmy will be less if you put it on the rear.
Peter
Old 04-13-2010, 07:03 PM
I will check the rims- I did put a cheap set on it just so it could be driven. I'm really thinkin a warped rotor could be the cause. And I have to replace the CTS and iris valve. But... These were halfway expected due to sitting for 2 years.
Btw- anyone have a 97 grill for sale? I would trade a good 92 grill...
-smileycaver
