Old 07-02-2010, 08:46 PM
Red94Svx Red94Svx is offline
cigarette lighter fuse help
Do you know what fuse and where its located thanks
Old 07-02-2010, 09:26 PM
Wikedjuggalo's Avatar
Rebuilding
Re: cigarette lighter fuse help
First column 5th row labeled Cig/Mirror a 20AMP.
Also this link might be handy if you are having issues with it blowing a lot
http://www.subaru-svx.net/forum/showthread.php?t=52869
Old 07-02-2010, 10:31 PM
If replacing the fuse doesn't help, it may be the fusible link installed at the rear of the lighter assembly.
For some odd reason mine failed and I thought it was a bad lighter assembly and decided to replace it.
After I got the old one out I noticed the fusible link had blown. I have never seen this before and am not sure why it it would blow instead of the fuse. In the picture above you can see the shriveled portion of the fusible link where it melted. I did a continuity test between both ends and it read open. I replaced the fusible link with a piece of heavy-gauge straight wire. Absolutely no problems since.
I normally would not do this, but I only use the lighter socket for very low current items, like my cell phone charger (1.5A), and my plug-in voltmeter. Would never use it for a high-current draw (heat) item like a cigarette lighter.
Old 07-02-2010, 11:03 PM
Thank you for your help it was the fuse I pulled it out and it was done lol that is the last time that I plug in my radar dectector. And 2 phone chargers lol what is the limit b4 I blpw the fuse?
Old 07-03-2010, 06:49 AM
Probably a radar detector and 1 phone charger!
If it's a 20 amp fuse, I'd say around 19 amps if you want to push the envelope.
Old 07-03-2010, 07:00 PM
Trevor's Avatar
Trevor Trevor is offline
I normally would not do this, but I only use the lighter socket for very low current items, like my cell phone charger (1.5A), and my plug-in voltmeter. Would never use it for a high current (heat) item like a cigarette lighter.
This integral fusible link is a safety device which will open in the event of excessive heat, rather than current. If the lighter jams and continues to heat there is a risk of fire.
Trevor, New Zealand.
Old 07-03-2010, 07:07 PM
Now that's a great idea.
Removing the fusible link, not such a great idea! Along the lines of removing the batteries from your smoke detector.
I wonder if all car lighters have this safety feature built in?
