Old 12-25-2008, 06:51 PM
jakea jakea is offline
EG33 Impreza RS
Common things to go out on an eg33
Hey guys, Im doing an EG33 swap into my 00 RS coupe. Ive got two engines, 1 an obd2 engine with ecu and an obd1 parts motor(bad bearing). The obd2 will be running the car, but it has sat for a while.
what I'd like to know is the most common parts for failure besides internals. Comp is great, plugs look great, perfect oil when drained.
I'm scared that something might not fire up the first time!
I'm only 17, so be gentle
Jake
Old 12-25-2008, 07:34 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Common things to go out on an eg33
Check timing belt,pullies,waterpump. etc
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 12-25-2008, 07:39 PM
These motors are extremely reliable. Usually good for plenty of miles. A few have put over 300,000 miles on their svx and many more with over 200,000. They're also widely popular for use in aircraft so that alone should tell you something.
As far as what can go wrong, only a few people have had head gaskets go but even when that happens, there usually isn't damage done if noticed and fixed right away. A few have also had spun bearings-currently my engine has a slight knock probably due to that yet still has good power. I believe someone elso on here has driven with a knocking motor for well over a year now.
Main thing is just to maintain it well.
-Nate
Old 12-25-2008, 07:49 PM
EG33 Impreza RS
awesome thanks guys.
how about the coils? they seem to be my main concern for some reason.
Also, are these engines interference?
2000 Impreza RS-EG33
1995 Impreza L-ej22
1992 SVX LSI- gutted and scrapped
Old 12-25-2008, 07:50 PM
Wikedjuggalo's Avatar
Rebuilding
Meah just keep an eye out nothing major like head gaskets in old Acuras or anything like that mainly SVX fault were the transmissions
Old 12-25-2008, 11:06 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
They're non-interference heads, which is probably why so much power is found from doing even the mildest of headwork. Coils don't seem to be an issue at all. Don't they have a writeup for this yet on RS25.com?
Old 12-25-2008, 11:12 PM
EG33 Impreza RS
I'd have to say im one of the eg33 into and impreza pioneers, that is for the common folk...
1995 Impreza L-ej22
Old 12-25-2008, 11:26 PM
Mensaf's Avatar
I know of a few EG33 swapped Imprezas. I almost bought one guy's swapped GC sedan about a year or so ago. Red sedan, and I know he has a video up on youtube too. Pretty sure I saw him on RS25 at one point or another.
Old 12-26-2008, 02:59 AM
Yes they are non interference motors.
A few people have had problems with coils but thats mainly been on motors with over 150k on them so nothin really to worry about-its pretty much a random happening.
Old 12-26-2008, 07:08 AM
The front diff's seem to be a bit fragile.
blk 92' LSL w/ average mods
Old 12-26-2008, 09:55 AM
RSVX RSVX is offline
Network Design Administrator
Um... since when is the front diff part of the eg33?
Life is a game. Play to win.
Old 12-26-2008, 03:47 PM
oab_au oab_au is offline
He is probably just Confused, Chris.
I would replace the Temp sensor, all the timing sensors, two crank, one cam sensor, PCV valve. These give the most common problems.
One Arm Bloke.
Tell it like it is!
Old 12-26-2008, 09:05 PM
kwren's Avatar
kwren kwren is offline
Jake
Great choice of tools!!
Old 12-27-2008, 03:45 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
dont forget knock sensors! those are the most common failure point of these engines
- John
Old 12-27-2008, 04:31 PM
kwren's Avatar
Harvey.....I would replace the Temp sensor, all the timing sensors, two crank, one cam sensor, PCV valve. These give the most common problems.
Sube Fan... dont forget knock sensors! those are the most common failure point of these engines
Kwren...throw in some temperature sensors...
Must not leave out the "yourconfused" front diff thingy!
Those little items will probably get us up to a few thousand dollars?
Maybe just drive it if it runs
Keith
