Old 09-04-2020, 04:59 PM
Hangtownsvx Hangtownsvx is offline
transmission dropping out of 4th
Either 4th is dropping out at 60 to 80 on slight hills or could it be the torque converter un locking? It is only about 500 rpm so I wouldn't think it is dropping a whole gear. How can I trouble shoot the torque converter in the car?
Old 09-05-2020, 06:59 AM
SVX_MY_BABY's Avatar
Re: transmission dropping out of 4th
Sounds like the torque converter unlocking and locking. Pretty normal in my experience.
Peter
Old 09-06-2020, 09:23 AM
If it is the toque converter, it is doing much more than it used to and I have driven it for more than 200000 miles. What would wear in it? or is there an electrical signal that goes to the torque converter?
Old 09-06-2020, 04:03 PM
Mine is doing the same thing but right at 80 kph (50 mph). I was thinking maybe the throttle position sensor had something to do with it.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 09-07-2020, 11:19 AM
I have been reading the big factory manual and the trans computer has some imputs before sending a signal to the duty solenoid B.
Vehicle speed sensors 1 and 2
engine speed
throttle opening
ATF temperature
what gear or range is selected
Also it wants to know if cruise control is in use. I always suspected that lock up stayed engaged more when cruise control was in use. I haven't nailed that down at all.
Fault codes are indicated via the Power light flashing.
Old 12-13-2021, 11:57 AM
I am going to get my spare trans rebuilt and use a new torque converter this time. Anyone have a source for a new or rebuilt torque converter?
Old 12-13-2021, 05:29 PM
Sounds like a tps issue. If it's reading a higher tps it will unlock the tc in expectation of heavy throttle input.
On a side note, I put a fwd Impreza trans I put in my fwd svx and I used the Impreza converter. Turns out the converter would lock only once and would later unlock and not lock again until I cycled the ignition. Never figured out why it did that but putting an svx converter in it later fixed it. Not sure on your situation if it's related
Old 12-14-2021, 01:00 AM
svxnavyvet svxnavyvet is offline
I picked up one of these . Have not installed it yet. Tom you might take a look at it make sure it is the correct one?
https://www.ebay.com/itm/26275131359..._redirect=true
here is the direct link
https://www.floridatorqueconverters....ter-69-32.html
Old 12-14-2021, 04:25 AM
Here's a cheaper fix. OEM TPS in no longer available but here's a solution:https://speedyefi.com/product/tps-ad...VvpUpxx-LZfH8U
$75.
Old 12-14-2021, 11:43 AM
If the Florida one really is the right one, I am interested. I better call to verify.
Old 12-14-2021, 05:08 PM
ya Isaac dalton lives in my home town we have talked about the tps he made the conversion so far everyone using it likes it.
$75.
Old 12-17-2021, 03:34 PM
Yea no idea if that's going to have the correct stall on that converter but it "should" work. When I had the wrong one in my car it was visibly smaller in girth
