Old 03-05-2011, 05:55 PM
Jonnycash's Avatar
Jonnycash Jonnycash is offline
electrical problem
Here I am sitting on the side of the highway waiting for a flatbed. I was cruising around 75 when all of a sudden my dash lights started flashing, headlights went off, power locks started freaking out and the car stalled. I smelled a wire or something electrical burn, but that went away. The main fuse link was burned, and the car would not crank or do anything. I checked all other fuses and they are good. I reconnected the fusable link and the car cranked over, no start. Upon further inspection I noticed no dash warning lights come on when the key is turned on, which makes me think the ecu is not getting power. Any ideas or thoughts would be great as I was on my way from connecticut to florida. Just glad it died close to home. I gave a look around under the dash and under the hood, but I don't see any burnt wires. Thanks in advance for your thoughts.
Giving money and power to government is like giving whiskey and car keys to teenage boys. – P.J. O'Rourke
Old 03-05-2011, 06:06 PM
Jonnycash's Avatar
Re: electrical problem
Update... Radio works, headlights/parking lights work, interior lights work.
Windows/sunroof don't work, door locks seem to be stuck down, but lock and unlock with the key. Cigarette lighter is not working, so my phone is going to die.
Old 03-05-2011, 09:07 PM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
i really cant help you, but my cigarette lighter has been broken for months... good fuse, no idea why...
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 03-06-2011, 01:04 PM
Jonnycash's Avatar
Well, drove a rental car (ford focus...) to ga, and had 12 hours to think about it...
Turns out the cig lighter still worked, the fuse was blown in the phone charger. Fixed that and now the phone won't charge. Got a new battery and it charges fine.
I am wondering if it is possible that the alternator was over charging (bad regulator) and cooked the ecu and my cell phone battery.
Any thoughts on this... Plausable?
Old 03-06-2011, 01:13 PM
A fuse or fuses and/or fusible link should have blown before any other damage occured but auto electrics is not one of my strong points so I may be wrong.
Old 03-06-2011, 03:17 PM
sd2649's Avatar
Driving in Style
Increasing voltage will actually not trip a fuse if it is only by 3 of 4 volts. Increasing amps (usually by a short) is what fuses are made to react to. In fact, increasing voltage is a way to get more electricity (measured in watts) through a smaller wire (or tiny wire in a fuse) with less heat buildup and resistance.
-Steven
SOLD
Old 03-06-2011, 03:33 PM
oab_au oab_au is offline
Any thoughts on this... Plausible?
Yes it is plausible. From what you say it does sound like the link has blown and the voltage has gone high, to cause some electrical damage. Did you notice, when it happened, did the headlights get very bright before they went out?
Check all the Slow Blow fuses in the under hood box. They are the small square ones, but from past posts, there may be units that may have died.
PS. We need an electrical modification to prevent this from damaging the electrical system, when the reg goes. John?
One Arm Bloke.
Tell it like it is!
Old 03-19-2011, 01:16 PM
Jonnycash's Avatar
Ok, so I finally had a chance to work on this thing. I have it running, but it still has some issues.
I got the alternator tested and it turned out to be overcharging. Replaced that.
The battery would not take a charge... replaced that.
The Horn/brake fuse was blown. I replaced it and the horn went off. I disconnected the horn and put the fuse back in and its fine.
The relay for the right fan was stuck open, and the fuse was blown, replaced them and the fans work.
The issues I have left are:
The horn.
The abs and airbag light are on on the dash. The fuse for the cruise/abs blows everytime i put it in. Which I assume is the reason for the lights.
I replaced the fusebox, but that did not change anything. Any ideas?
Thanks!
Old 03-20-2011, 01:39 PM
Jonnycash's Avatar
The horn.
Thanks!
I dorve it yesterday and found more problems.
I only have fwd, and the transmission shifts funny...
The best way I can describe it is if you shifted a standard to soon, it kind of lugs up to speed. It only does this under half throttle. It shifts fine when you get on the gas. Also, when you are coasting and move the shifter to a lower gear the rpm's drop as if its in neutral. In Drive it acts normal.
There is a parasitic drain on the battery, and it is dead after only a couple hours of sitting.
I don't know if I have it in me to track all of these problems and fix it.
