Old 07-06-2018, 01:59 AM
Steve Watson Steve Watson is offline
Door Lock Issue
Hi Folks,
I recently purchased a 1993 Subaru SVX as a project to keep me busy.
I need some help, when purchased it came with one key and no remotes, problem being that I am unable to unlock the doors from inside or outside with or without the key, all fuses appear to be OK.
Is there something I should be fixing or replacing?
Any advice & help would be greatly appreciated.
Regards
Steve
Australia
Old 07-06-2018, 05:09 AM
Re: Door Lock Issue
When just the remote is used to unlock the doors for long periods, the keyed lock can get stuck, from lack of use, spray a little graphite into the locks, and keep working it with the key, it should loosen up with some work.....if not next step would be remove the door panel and make sure all the lock rods are good, and functioning, then you could take the lock cylinder out and let it soak in some cleaner....but be sure to put a little graphite back in it when you get it all working, to help keep it lubed..
Old 07-07-2018, 06:33 PM
Re: Door Lock Issue
Thank you for advice, but unfortunately that doesn't appear to be the problem.
It seems to be stuck in the locked position and the only way I can open the door is by pulling up the internal lock button as much as possible and opening with the external handle.
Obviously I need to leave the window down or I would be locked out.
All the rods appear to be OK and I have tried removing the door lock fuse.
The car only came with one key and no remotes.
Any other thoughts would be much appreciated
Cheers Steve
Old 07-07-2018, 06:41 PM
Blacky Blacky is online now
Re: Door Lock Issue
Not that it matters much but not all of them had remotes. My otherwise loaded '97 had no remotes.
Old 07-08-2018, 01:05 AM
oab_au oab_au is offline
Re: Door Lock Issue
Originally Posted by Steve Watson View Post
Hi Folks,
Regards
Steve
Australia
Steve the Australian car doesn't have any security, like the US ones, so no remotes.
Does the passengers door do the same?
One Arm Bloke.
Tell it like it is!
Old 07-08-2018, 03:08 AM
Re: Door Lock Issue
Yep! Passenger door has the same issue.
Thanks for the response.
Old 07-08-2018, 03:30 AM
Re: Door Lock Issue
You haven't pushed the "LOCK DOORS " switch near the window switches?
One Arm Bloke.
Tell it like it is!
Old 07-08-2018, 03:58 AM
Re: Door Lock Issue
Doesn't appear to have a Lock Doors button near the window controls.
Old 07-08-2018, 06:17 PM
svxnavyvet svxnavyvet is offline
Re: Door Lock Issue
mine is doing the same thing
Old 07-17-2018, 08:22 AM
abovetherim abovetherim is offline
Re: Door Lock Issue
I wonder if aftermarket remote actuators are fitted and resisting the unlock?
Either way I would be pulling the door card off and pulling the lock mechanism out to check it.
