Old 03-17-2003, 01:49 PM
Paxton71
Question Front wheel bearing tips and tricks?
I have done a search. I read Beav's comments on slide hammers and stuff. I do have a 12T press.
Any DIYs who have done this? I value the knowledge of "those who have gone before!" Hints/tricks?
Thanks
Old 03-17-2003, 11:00 PM
Paxton71
now that it is done, I'll post a couple
Well, that was fun.
Yes, you do need a press. The bigger the better.
My 12T didn't move the race until I started wailing on the cast housing with my hammer.
I wouldn't bother trying to do it on the car with a slide hammer.
These units were not designed to be serviced. A couple of machined notches in the housing ridge would let you get after the race with a punch and a hammer instead of a press...But that isn't part of Subaru's plan. (It was on my Volvo and Toyota.)
The FSM doesn't mention or picture that you have to have the rotor dust shield on BEFORE you start pressing the hub back together. It wouldn't be a problem if you left the pulse ring for the ABS off...
The old bearing race is great for installing the new race. The race is so thick that you can get it all the way home with the old race driving it without driving the old race into the housing (where it is hard to remove).
Toyota 8 inch differential pinion gear bearings are the perfect size for driving the bearings onto the hub shaft.
I can't figure out what keeps the hub in the bearings either. If it were not for the caliper bracket and the rotor, I think the wheel could fall off! *laughs* Why isn't there a snap ring on the hub shaft too? That would keep the shaft in the bearings better than an interference fit. I guess it's OK, it jsut doesn't sit well with my old(er) school mechanics.
I'm an old(er) school shade tree wrench turner. I prefer a brass hammer or punch to a press when installing bearings and races. I have better...FEEL. I also enjoy packing bearings by hand instead of with a bearing packer. (I know, a pro shop just doesn't have time to hand pack bearings)
Old 03-18-2003, 04:31 AM
svx_commuter's Avatar
Thanks for the information.
Old 03-18-2003, 10:31 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Don't ya just love looking down and seeing a part that should have gone on before you just pressed that last piece into place? Not that I've ever done that... heheheh
For safety sake never strike a race with another race. Never strike one hammer with another. The reason is that they are hardened pieces and can shatter, sending pieces of sharp metal into your flesh and/or eyes.
Once the cv shaft is in place and the large nut is torqued down there's no place for the hub to go.
BTW, the HubTamer makes a 30 minute job of this (the fronts are easier than the rear.) It's worth the money if you do these regularly.
Old 03-18-2003, 11:52 AM
Paxton71
Thanks, Beav
Ah, that's right! The CV joint will stop it from backing out. I feel MUCH safer!
Thanks for the safety tip on race on race. I'll keep that in mind. (time to go buy the big snap-on driver set, eh?)
I really don't plan on doing wheel bearings too often. *laughs*
Old 03-18-2003, 12:39 PM
alia176 alia176 is offline
Speaking of Hub tamer, wouldn't it be great if we can just rent the set from Beav! Then send it to the next guy who needs it. Mean while Beav just gets the rental fee from one guy to the next!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 03-18-2003, 01:10 PM
Beav's Avatar
Not as old as Randy
Yeah, and the shipping cost will make it all worthwhile. I'd guess around 45#.
Old 03-20-2003, 12:55 AM
The Molinator
Smile Tame THIS!
Beav, I don't know if you saw from my (Rear Bearing) thread that I (in a weak moment) bought a HubTamer (from usatoolwaehouse) off eBay last weekend (for $205.) to do my rear bearings (you scared me, alright!). Don't have it yet, but the nice picture makes it look like a dandy little kit.
Well, I guess we'll have to start a price war on our HubTamer rental fees! I'm gonna give a discount to anyone who picks up the HubTamer for rental personally (to save those heavy shipping charges, huh!)
[Maybe if we send the HubTamer "book rate" (they'll never know!), our HubTamer rental business will boom!]
I'll let everyone know how mine works.
Jim
Old 03-20-2003, 11:31 AM
Since you don't need to use the entire tool set for a typical wheel bearing job, maybe we can just rent what's needed. But realistically, I rather have my own set since I got two subies. It was just a humorous thought!
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 03-20-2003, 04:10 PM
Beav's Avatar
Not as old as Randy
You can have all the rentals you want. I'm stingy and want to keep mine all to myself. "I'm sorry but I can't do your wheel bearings until so-and-so in Timbuktu returns my tools."
