Still looking BIG BRAKE upgrade
Still considering upgrading the stock brakes and came across this company that sells a 6 piston brake system for the STI that has the same 5x 114 pattern as the SVX. Haven't contacted them but want to know if anyone has looked into this system ;http://www.alconkits.com/index.php/B...Brake-Kit.html
Re: Still looking BIG BRAKE upgrade
WOW !!!!
what a cost - nearly as much as most cars are actually worth!! I just upgraded mine, Pads from http://ebcbrakes.com/product/redstuff-brake-pads Covered brake lines from http://svx-motorsport-accessories.st...rakandsus.html Rotors from motorsport (above) www.r1concepts.com - full drilled/slotted & gold passivated All shipped to me in New Zealand....and still only 40% cost of buying OEM from local Subaru agent here. They make the car stop much better - with no fade......and a lot cheaper than what you are proposing.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Please use the search function, or check out the mod mania section. In there is a section including brakes and you will find threads on adapters that a few have made and some that are for sale as well as reasons why the STI brakes still need modification. Bolt pattern is only a fraction to consider when it comes to customizing brakes from another vehicle to fit.
Thread Tools | |
Display Modes | |
