Old 10-18-2013, 09:29 AM
subezealot's Avatar
subezealot subezealot is offline
My SVX starts up, goes briefly then stalls out .. fuel related?
Looking for advice on this..I'm guessing either I've got a badly blocked fuel filter, or it's time for a new fuel pump. After the car stalls it won't restart again until it sits for a while. Then it will start again and only go a bit. Has anyone run into this?
96 LSi - Hyper Blue, 5 Speed - Magnaflow - Murano take off wheels - 70K
Old 10-20-2013, 10:07 AM
stiguy's Avatar
stiguy stiguy is offline
Re: My SVX starts up, goes briefly then stalls out .. fuel related?
I'd start with the fuel filter easy access and only about $20
#1 1994 Ls ebony parts car-rip
#2 1994 L laguna blue - sold
#3 1992 Lsi pearl white - sold
#4 1992 Lsi pearl white -Ate two engines - Rip
#5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree
#6 1992 Lsi custom orange parts car
#7 1992 Lsi green 4.44 swap. Currently for sale
#8 1992 Lsi custom pearl white. Project car... sold
#9 1992 Teal 4.44 swapped... sold
#10 1995 Laguna Blue. Sti 19 wheels,
#11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂
Old 10-20-2013, 10:58 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Does it idle rough before it dies or is it like if someone 'pulled the plug'? Have you checked your MAF?
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 10-21-2013, 12:08 PM
subezealot's Avatar
Thanks for the input and suggestions. I started with replacing the fuel filter and the car started right up (sort of as usual) and ran. So I ruled out anything on the pump side. I let it idle a while then it shut down. Here's the root cause...it was a bad battery. I've never had a battery situation where it would start the car, then run, and then basically just drop down on the voltage enough that the car just quits. I will check the alternator as my next step in the process. Thanks for the help.
Old 10-21-2013, 01:08 PM
subezealot's Avatar
