Old 01-04-2013, 02:05 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Re: What did you get for christmas?
Originally Posted by Coan View Post
I almost bought the same front pads and rotors for xmas! Only reason I didn't is because the car isn't running properly. Once I figure that out then I'll order them....
I guess it's the season for brake jobs!
Heh, mine isn't either, but I've been driving on horribly warped rotors for a couple of months now! (I think the wheel shake from it is opening my seals in my steering rack every time I brake, causing ATF to leak onto my exhaust which makes a nice smoke effect. )
I'm having the same weird problem you were having, except now mine's misfiring even during acceleration and stops misfiring after the car is off for at least 5 minutes after fully warming up.
Replacement TPS from Nate on the way, and once I get my phenolic spacers from Bobby I'll be replacing all the vacuum mess under the manifold as well.
ANYHOW: I'll let you know how the brakes are once I install them, as well as if I find a fix to lower our pesky high idle.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 01-04-2013, 05:38 AM
Gamesy's Avatar
Gamesy Gamesy is offline
Originally Posted by bishop View Post
haha, i didnt get fat because i couldnt keep anything in XD
i got two armor all car care kits but from what i hear they may not actually be that good for the car.
I've heard excessive use does it. over time its dries out the material causing it to crack prematurely
Old 01-04-2013, 08:32 AM
theflystyle's Avatar
i would avoid using armor all and try a product called Aerospace 303 (http://www.autogeek.net/16oz.html). Ive used it for years and is by far one of the more highly suggested products
1994 SVX LSi
2008 Legacy 3.0R
Old 01-04-2013, 08:47 AM
Coan's Avatar
Coan Coan is offline
Alleged User
Thumbs up Re: What did you get for christmas?
Definitely keep me posted on both situations!
Jon
1997 SVX LSi Bordeaux Pearl
1995 SVX L AWD Polo Green - 277k miles
1986 Pontiac Fiero 3.4L Twin Dual Cam V6
