Old 08-06-2012, 11:21 AM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
No crank
So i did a drive train swap finally in my 94L with 92ls. The 92 drove fine but had some issues cosmetically in and out.
Well after everything was removed and replaced, I was going to fire up the 94 with 92 drive train but no crank! What could it be? Had no time to check voltage at starter.
Help please and thanks
Btw indod change ecu and tcu
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 08-06-2012, 02:40 PM
dragoontwo dragoontwo is offline
Re: No crank
Did you fit the little slip spade connector to the starter?
'92 SVX LS Pearl White - 6mt
Old 08-06-2012, 07:02 PM
VICSVX's Avatar
Never Forget
Re: No crank
i connected that little bugger and made sure i had a good battery....still nothing
VICSVX
Old 08-07-2012, 03:47 PM
gbianchi gbianchi is offline
Re: No crank
Tranny switch on trans lined up correctly, is the park light lit, try in neutral, anything wrong in those areas will not let it crank.......G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 08-09-2012, 05:22 PM
VICSVX's Avatar
Never Forget
Re: No crank
well we (dad and i) didn't line up the shift lever and the tranny switch at first. so with the shifter in park, the light on the dash was in reverse. we jacked the car back up and disconnected cable from tranny and put the tranny in park as well still no start.
we will adjust the tranny switch to correlate with the shifter this weekend but as it is now, it still should start right?
VICSVX
Old 08-13-2012, 09:08 PM
VICSVX's Avatar
Never Forget
Re: No crank
update
got the car started....the split spade ground wasnt making a good connection and thus no start....so thanks gbianchi and dragoontwo
as for the trans seeming not to work, the trans was empty! i didnt drain the trans when i was R&R but it did leak out the lines so i must have lost that much in the 2 days i was working.
just thought i would end the thread as i hate unfinished threads lol
VICSVX
