Old 05-10-2012, 10:46 AM
Huskymaniac's Avatar
Uses the ignore feature
Do replacement wheel bearings need to be re-packed or not?
As I mentioned in another thread, I got some information from Timken that contradicts what many people on this forum have said. According to Timken, the bearings come packed in grease that is sufficient in both quality and quantity to be installed as-is. They did mention that, if you are going to re-pack them with a better grease to completely clean out the original grease. So they imply that there is better grease out there but that you don't have to re-pack them. They said only their unit bearings on rear axles come with shipping grease sufficient only for startup operation.
Was the grease issue just with bearings purchased from Subaru? My mechanic said that they just install the bearings with the supplied grease unless otherwise instructed. I didn't ask him if that was aftermarket bearings like Timken or all bearings including the ones supplied by Subaru. Perhaps the repeat failures people were seeing were mainly due to the hubs needing to be replaced, use of crappy seals or incorrect torque used when installing them instead of the grease in the bearings.
Thoughts?
Tony
Old 05-10-2012, 01:06 PM
zaueugen's Avatar
zaueugen zaueugen is offline
Re: Do replacement wheel bearings need to be re-packed or not?
i used timken and i repacked them with mobill synthetic grease and put about 10,000 miles... no problem thus far..
Old 05-10-2012, 01:13 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Some vehicles (like trucks with solid rear axles) have bearings that get lubricated by the oil from the differential. But when you replace the bearings, there is no oil in them to start with, so they are supposed to have some grease at start up. I'm guessing that's what they were referring to.
Obviously, that's not the case with our cars. I personally would repack any bearing I install just because then I know exactly what kind and how much grease was used, and that it's clean
My 2¢.
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 05-10-2012, 01:56 PM
92 SVX 92 SVX is offline
Thoughts?
Take this for what it is, hearsay
From what I have read the subaru bearings are shipped from overseas and to keep the saltwater damage down they are coated with a different grease and so when you get them you need to clean them completely and repack them with the correct grease.
Now other companies Ie timkin may use different procedures. Personally I got to agree with SVX8588 it only takes a little time for true peace of mind.
Old 05-10-2012, 02:01 PM
I agree but one can also re-pack with too much grease so there is some chance to screw it up whereas Timken says that they ship their bearings with the proper amount of grease. Not too much and not too little.
Tony
Old 05-10-2012, 02:39 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Tony, the previous owner of my 97 ebony had his rear bearings replaced four times within a four year period from the Subaru dealer. Sounds like they just put them in with the packing grease. My mechanic replaced both rear bearings in my wrecked 96 timken, and left rear in my 96 polo timken both which I no longer own, and we washed out the packing grease with brake cleaner, dried them off and repacked them by hand with Amsoil red synthetic grease. No problems and quiet as a mouse. Your asking for trouble if you dont repack them with proper grease
1995 POLO LSI 76K MILES SOLD
Old 05-10-2012, 03:18 PM
Sounds like an untrue hub....
Old 05-10-2012, 08:10 PM
kwren's Avatar
kwren kwren is offline
For many years SVX owners have felt the consequences of not repacking the wheel bearings with grease before they were installed. They were originally sold packed only with only a substance that protected the metal surfaces of the components in the bearing between the time of manufacturing and were sold to the consumer, and installed.
It would make no sense to just install them without making sure they are correctly greased. What "some guy" that answers the phone at "tinkers" said would never be good enough for me. That could even be where that old saying "not worth a tinkers damn" came from!
Considering the history of problems from not flushing the bearing out and installing them the way they are when sold. I for one would take the little effort required and make sure it is correct. Too expensive and time-consuming if it isn't done correctly.
But... that is just me.
Keith
Old 05-10-2012, 08:45 PM
Subaru issued a new TSB regarding wheel bearing installation, saying not to repack their wheel bearings with any kind of grease and they were ready to install out of the box.
http://www.downloads.bustedfingermot...20bearings.pdf
I had heard before that the SVX wheel bearings stopped using the light shipping grease and were now packing them with the correct grease.
Old 05-10-2012, 10:53 PM
kwren's Avatar
That's great!! But... I quickly pulled up the information and scanned it a couple of times. The information was specific about Subaru's however, I didn't notice SVX anywhere. I would have no way of knowing how many years the wheel bearings had been around for our cars on a shelf somewhere and would feel more comfortable with "SVX" listed on the safe types that that link referred to.
Maybe you have more information? After all, you are always "full of it"
Just kidding, of course... You are invaluable for us all...
We are blessed on this site!
Keith
Old 05-10-2012, 11:14 PM
Aint that the truth...
Old 05-10-2012, 11:56 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
Def repack! Check my locker for how to with pics
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 05-11-2012, 04:52 AM
The original post refers to Timken bearings not Subaru.
The repeat failure of Subaru bearings for many years was due to them having shipping grease which was to stop corrosion only. I have never heard of the same bonehead mistake being made by any other manufacturer.
Old 05-11-2012, 06:06 AM
Correct! And it wasn't some yahoo from an internet parts store I talked to. It was a representative from Timken! From what I have gathered, even the Subaru bearings now come properly greased. The real problem seems to be that incorrect torque is often used on the key nuts which damages the hub which then destroys the new bearings, not the grease. If one was certain they could properly clean the bearings and repack them completely but not excessively then, yeah, it won't hurt. But I think the install is the key. Damn you Nate and Tom for being so far away!
By the way, these bearings are used on some of the newer Saab 9-2x and Subaru STi models so I doubt there are any of the improperly greased bearings hanging around in stock rooms.
Tony
Old 05-11-2012, 01:07 PM
It's very easy to do actually, just eye-balling it. I think you're over-thinking this one. Just change the grease so you know that there's good grease. The grease they come with pretty much fills up every space in the bearing, so it's not like you can really fill it more than it was already.
