Old 04-23-2012, 08:37 PM
redlightningsvx's Avatar
Collision Refinishing Tech
camber kit questions
So When I got new tires put on a month or so ago I had the car aligned and my FR tire is -1.75 and my RR tire is -1.5 or 6. I bought 2 camber kits which comes with 2 bolts worth +-2 degrees per bolt. Now my question is if the one bolt doesn't fix the camber it says to use the other for the bottom bolt for a total of +-4 degrees of camber. The bottom bolt stock is a solid not eccentric bolt and wasn't sure if it would be ok to put it in there if I need that extra camber.
Here's the kit I got....http://www.ingallseng.com/81260-14mm...olts_pair.html
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 04-24-2012, 05:23 AM
Re: camber kit questions
Yeah, we used them on the top and bottom holes of the racer to get the most camber.
Old 04-24-2012, 08:59 AM
My subaru mech was worried about putting an eccentric bolt where the solid bolt was because of the extra space in there and hitting a bump would throw it out. I guess i'll throw them on then. Thanks Dave.
Seth
Past subies:
Other toys:
Old 04-24-2012, 09:43 AM
This was on the racer, so things came apart every 20-30 miles or so. I would make sure they are plenty tight and keep an eye on them.
The brand we got had crimped threads on the nut to keep things together. If yours don't have that, I'd use some threadlock.
Old 04-24-2012, 11:46 AM
The nut opening looks oval so it should be good but ill put some locktite on just in case.
Seth
Past subies:
Other toys:
