Old 03-21-2012, 11:54 AM
Tapani Tapani is offline
Prop shaft center bearing?
How to tell if the center bearing is good or bad? Should it be co-centric with the carrier? The rubber seems fine, no tears. the bearing itself has a tine bit of play, but it's smooth. The only thing is the shaft is not co-centric with the metal support (see attachement).
Thanks,
Tapani
Old 03-21-2012, 01:24 PM
Re: Prop shaft center bearing?
it's fine if the shaft sits a little lower in the rubber like that, the rubber isn't very hard so it's allowed to move up and down. if the bearing isn't making noise and you don't get any thumping up and down as the shaft spins it's probably fine. are you having a problem with it or just noticed the droop?
Old 03-21-2012, 01:32 PM
Thanks,
Swapping trannies and noticed it when I took the exhaust system down.
I look closer when I remove the shaft.
Tapani
Old 03-22-2012, 07:53 AM
dragoontwo dragoontwo is offline
You'll find that it is designed to sit off center like that.
'92 SVX LS Pearl White - 6mt
Old 03-22-2012, 11:39 AM
showoval showoval is offline
Subject realted: Mine sits a little low, I had to bend the heat shield down so the prop shaft wouldn't vibrate on it at low speeds. Is that normal with only 95K on the car?
Old 03-22-2012, 12:04 PM
Ok, I took it off... the U-joints are bad.
Has anyone replaced them? Or do you just buy a whole new shaft assy?
Tapani
Old 03-22-2012, 12:42 PM
you pretty much need to get a whole new shaft. it is possible to replace them but not worth the time to do it.
Old 03-22-2012, 04:47 PM
For him, getting a new driveshaft will be very costly. Find a shop to put in new u-joints that are also greasable/serviceable. When YT was doing MT driveshafts here stateside,he was also getting these type of u-joints put in and was still able to keep the cost way below a new Subaru shaft here in the states. (around $200 including shipping each way on the MT shafts)
Old 03-22-2012, 04:50 PM
you are right, i did not see that he was in finland.
Old 03-22-2012, 10:00 PM
Yeah, sounds like a plan. It appears a new shaft is ove 500$ + shipping + VAT and customs.... 7-800$ in total. That's quite a bit
I know a good prop shaft shop - need to talk to them.
The center bearing seems fine, except the rubber bellow "looks old" and sags toward the bottom
Thanks guys,
Tapani
Old 03-23-2012, 07:32 PM
immortal_suby's Avatar
Thread Killah
Thanks guys,
Tapani
Going by your picture, it looks perfect to me.
Locker Link
2015 BRZ Limited 6MT
