Old 03-15-2012, 03:15 AM
Chip Hutchinson Chip Hutchinson is offline
Poor gas mileage.
Hi guys. My '97 with 85K on it gets 17 MPG on the same commute that my '96 used to get 21 MPG on. The car runs great and the CEL is not on. Does anyone have any suggestions on how to go about investigating a problem like this? Any help is appreciated.
Chip.
Old 03-15-2012, 04:40 AM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Re: Poor gas mileage.
Check to make sure you don't have a sticky caliper. I got around 21 with mine until one of the calipers slowly started sticking. I watched the mileage drop to 17 over about 4 months before I realized what the problem was.
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 03-15-2012, 10:30 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
I get nearly 14 MPG in my 92 pearly.. Its terrible.
Old 03-15-2012, 10:53 AM
dcarrb dcarrb is offline
Chip.
Is torque converter lockup pretty much the same on both cars over the same route? All other factors being equal, that'll make a huge difference. Aside from that, the usual suspects: Tire condition and PSI, air filter condition, aging plug(s), wonky fuel injector, and so on.
In 100% commuter mode, I've found 17-19 MPG is about the best either of mine has to give.
dcb
Old 03-16-2012, 06:25 PM
Thanks for the help. It runs so well that I think I will check the calipers first.
Chip.
Old 03-17-2012, 09:30 AM
I cosider 17 in town pretty good. Of course what you call in town and what call in town can be two different things ( 6 traffic lights a mile or down town NY city or a rural town in Kansas ) I shift 21 times going to work and it is just under 2 miles.
Old 03-17-2012, 09:26 PM
flamestone's Avatar
flamestone flamestone is offline
Check the fuel delivery system too.
For example, if you've got a fuel pressure regulator on its way out (rubber diaphram perishing), it could be wasting fuel through that.
Old 04-25-2012, 10:48 AM
Huskymaniac's Avatar
Uses the ignore feature
Could that cause a lot of gurgling noises when the car is first started? How does one check the FPR?
Tony
Old 04-25-2012, 11:39 AM
the gurgling (if it is coming from the back seat area) is probably just the fuel pump. if you pull the vacuum line off the pressure regulator then you should be able to tell if it is leaking. the line will be wet inside, apply vacuum with a clear hose to be certain. when the diaphragm ruptures it allows fuel to be sucked into the vacuum hose.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 04-27-2012, 08:43 AM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
I previously had a 1:1 KM/L but now have about 1.2L per 10km.
It's a sticky caliper (FR). Teh pads look very and clean there!
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 05-03-2012, 02:56 AM
Thanks everyone.
The left front caliper was binding, and the right front caliper, while not binding, had a bad (frozen) piston. Now to see what my mileage rises to. BTW my commute is 12.5 Mi. It is ~2/3 Freeway. but for comparisons, my '96 got 20.5 to 21 MPG on that route. It had 213K, and I expect that from my '97 with 88K.
Chip.
Old 05-03-2012, 09:49 AM
jetboy's Avatar
Ironically, I didn't have a caliper issue
Must be the bad bearings.
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 05-03-2012, 10:26 AM
I once had a collapsing brake hose . When you applied the brake it would expand and when you released the pedal it would slowly resease the caliper.
Old 05-03-2012, 03:15 PM
jetboy's Avatar
Oh yes I tried nudging Sicksubie for those
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 05-04-2012, 12:01 AM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
mine has the same problem and does about 13-15 MPG
I'm pretty sure it has something to do with the spark plugs and the slightly warped brake rotors...gotta replace those
but when it was healthy i could get 22-23 highway MPG which is respectable...
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
