Old 02-17-2012, 10:36 PM
Red94Svx Red94Svx is offline
Extra fog lights
I got some extra little fog lights that I mounted on to the front bummer but need some help with wiring I want them to be on the. Same switch as the fog lights by the head lights but don't know how to wire them up please help pictures would be great too thanks for reading
Old 02-17-2012, 11:57 PM
Re: Extra fog lights
What you're doing may not be legal onroad FYI. You are only legal to have 4 forward facing lights on at one time.
Old 02-19-2012, 10:52 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
WOW Nate - that's is a bit rough, here in NZ there is no limit - I had 6 on my mini (2 + 4 spots).......
You could take a wire from the hi-beam side of headlights to a relay sense side, then hi-current from battery to relay & earth to the low side of relay - this setup will work with normal hi-beam stalk switch.
If you want to also fit a manual (hidden switch) then fit it into the initial line that runs from Hi-beam to relay line.
Old 02-19-2012, 03:00 PM
Jvan Jvan is offline
How would you wire the extra lights if I want to use the parking light switch on the lower dash next to the control for the mirror heater. Then they would be independent of stock fog lights.
Old 02-19-2012, 03:33 PM
SURTEESS's Avatar
Cool Re: Extra fog lights
We did not get the fog lights as an option here in NZ - there is a blanking metal plate inside the housing - thought about retro-fitting them into the original housing (even got lamps from USA model sent out here - maybe one day) - but prefer to keep my NZ housing as it has glass not plastic out front..
Old 02-19-2012, 08:24 PM
b4stard
Oh how I'd love a set of glass housings. I do have a friend in Germany.
Old 02-19-2012, 08:53 PM
Jvan:
What ever you want to control the light you would hook to the sense side of the realy.. What you are doing is using the power from one sorce such as the low beam bulb wire to throw a switch (in this case the relay that can take the big load ) and turn on the fog lights. The rely is a electronic magnet with contacts. When it gets a small voltage/ low amp signal to the magnet it energizes the magnet that draws the contacts together that are connected to a larger load and passes the high current to the lights. Not using a relay will fry the switch.
