Old 11-05-2011, 08:33 AM
Cam Cam is offline
11:1 CR Built Motor
Up for sale is the engine from my car. Look in my thread history for the thread on its build. I believe it is titled "11:1 Engine Build".
Here is a list of all the things that were done to it.
11:1 CR ECUtune Pistons
256 intake/ 256 exhaust ECUtune camshafts
Thermal coated pistons, and main bearings (supplied by ECUtune)
ECUtune rod bearings
All machine work was performed at Action Machine in Shoreline, WA.
370cc SR20 injectors
Z32 MAF
Everything on engine, EXCEPT alternator, AC compressor, PS pump, TPS, Crank sensor, Cam sensors and crank pulley are BRAND NEW.
New bolts in engine, new brackets, new timing covers, new pulleys, water pump, REBUILT oil pump. New vacuum hoses (blue silicone).
Machine work includes, Bore and 2-step hone of cylinders, light polish on crank, re-surfacing the heads, rebuilding of valve-train, balancing of entire rotating assembly (cannot recall how far it was balanced but it is upwareds of 10k rpm).
I am only asking 4k for the engine, and if you want it will stay in the car and you can come haul the whole thing away!
The car runs, but it idles like crap, since it runs so rich. You could maybe try to contact Mike at ECUtune to see if you could work out some better software (if you take it to a gas analyzer he may be able to adjust software according to the results), or you could slap a hydra on her. Either way, the engine is solid, and runs well in upper RPM's.
Contact me via PM with any questions. Don't be afraid to make an offer, I will entertain any and all at this point.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 11-15-2011, 07:53 AM
Nomad Nomad is offline
The car named NIGHTMARE
Send a message via MSN to Nomad
Re: 11:1 CR Built Motor
Why are you selling it? If you have not sold it, i could offer you 2,500$ for it, It needs a new software and dyno ajustments witch i can have for 1,500$... But is the rest of your car in good shape ?
Nightmare is the name of the car...
Old 11-15-2011, 08:58 AM
Cam Cam is offline
The car is in decent shape, but has it's list of things that need done. PM me if you are interested. I can't take 2500 for it but could probably work something out.
Cam
'92 Ls-L Dark Teal
Old 11-15-2011, 09:42 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
What ECUTune chip are you running?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-15-2011, 10:10 AM
Cam Cam is offline
Stage 2 aggressive
Cam
'92 Ls-L Dark Teal
