Old 04-03-2010, 12:56 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
exhaust work (need help)
if i get rid of the pre-cats on the stock svx exhaust will it give me a check engine light ? also i want to keep the stock svx main cat and put a new muffler (cherry bomb), how do you guys think that would sound ??? need input.
I has teh FWD LS-L
Old 04-03-2010, 12:59 PM
Re: exhaust work (need help)
I would suggest at least putting some Aero AR20 resonators in place of the pre-cats. Also, just putting a cherry bomb on instead a true muffler is not going to sound good under any amount of throttle. It may sound nice at idle but you will hate how it sounds under throttle.
Old 04-03-2010, 01:11 PM
92_LSL's Avatar
i was just trying to think of a low budget way to put an exhaust on my svx
I has teh FWD LS-L
Old 04-03-2010, 02:15 PM
I see. Well, if you remove the pre-cats, I can't say for sure if it will throw a SEL but its not going to add any performance. You will want to make sure to keep the resonator between the main cat and the muffler as removing it results in a very annoying sound above 2000 rpm. As for dealing with the muffler, you could always look into replacing it with a muffler from the last gen camaros/firebirds (not the new one). It will take some modification to the piping but will give it better sound and slightly better flow. Hope that helps a little.
Old 04-03-2010, 02:53 PM
1) The SVX is not a low budget car.
2) Leave the cats alone. (meow)
3) Remove the muffler, replace with two smaller chambers, either resonators or mufflers in a V config. Should sound ok whilst not deafening you on long rides (or you can go the Camaro route but I don't see the point).
Old 04-03-2010, 03:04 PM
sabin sabin is offline
Banned
i have both pre cats removed with no check engine light and no annoying sound
i also have a magnaflow high flow main cat and 2 magnaflow mufflers
Old 04-03-2010, 08:31 PM
92_LSL's Avatar
i know the svx is not a low budget car but there is always a cheaper way to do something without compromising build quality. i just want the best sounding, cheap exhaust i can make or find.
I has teh FWD LS-L
Old 04-03-2010, 09:01 PM
How handy are you with a welder?
http://www.subaru-svx.net/forum/show...+bomb+cat-back
Old 04-03-2010, 09:09 PM
92_LSL's Avatar
im pretty familiar with a welder but i want to use a single entrance dual exit main cat so there isn't a need to fab a y pipe
I has teh FWD LS-L
Old 04-03-2010, 09:16 PM
Such a creature exists? I suppose you could run a Magnaflow 94007 backwards... But you'll have to make a y-pipe of some sort either way, either to join before the cat or to split after it. Unless you go with a dual in/dual out cat, but then you've basically got a dual system.
Old 04-03-2010, 10:13 PM
92_LSL's Avatar
i saw a cherry bomb extreme series muffler at the auto parts store that was dual in and dual out. that seems like it would be the easiest way to do it. i just want it to sound like this.
http://www.youtube.com/watch?v=Jsgr8huE8o0
I has teh FWD LS-L
