Old 09-30-2009, 07:27 PM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
Angry More corroded wires?!
Ok so Killer Tomato had some corroded wires (power relay) under the drivers seat. Well back at Reading YT did a temp fix while I was waiting for the power relay from Annapolis Subaru. I replaced the power window relay. Worked fine for nearly 5 months...no problems. I went a couple weeks without driving the car (work, other SVX, bike) and realized my windows wouldn't go down again after I was pulled over by a cop. I know that when these wires corrode that none of the windows work, the seat doesn't move, and the sunroof doesn't work. Well I don't have a sunroof, the windows aren't working, but my seat still moves. Before I rip up the carpet under the seat...I was wondering who here would be able to tell me where to start looking for these wires so that I can replace them. Or what else can I do. etc etc. Sometimes there are always weird/easy fixes for these type of things. Any help is greatly appreciated. Thanks.
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 09-30-2009, 08:12 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: More corroded wires?!
Quick question, did you just try the windows with the main drivers switch or did you also try with the other door switches?
Old 09-30-2009, 08:25 PM
can you confirm you are losing power to the switch?
Old 10-01-2009, 01:35 PM
SVXyGirl's Avatar
Other switches are not working either.
I'm getting that buzzing noise again when I touch the switch. I don't play with it too much, I don't want to burn out the motor.
Rebecca
Past SVXs:
Old 10-01-2009, 02:02 PM
subeman90's Avatar
Soobologist
relays buzz when they are bad. Just a thought.
15 OBW premium w/eyesight
