Old 09-01-2009, 07:02 PM
Gamesy's Avatar
Gamesy Gamesy is offline
fuel pump fuse
instead of unplugging the fuel pump to make it easier to change the fuel filter is there a fuse for the fuel pump? if so where is it located, unless i'm blind its not in either fuse box.
Old 09-01-2009, 07:10 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: fuel pump fuse
Lifting the rear seat isn't easy to pull up?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-01-2009, 07:26 PM
Gamesy's Avatar
Re: fuel pump fuse
that would require getting out my ratchet set and stuff and finding where to lift it, i know i know i'm being really lazy about it
Gamesy's Avatar
Re: fuel pump fuse
but is there a fuse?
Old 09-01-2009, 07:27 PM
Re: fuel pump fuse
There's no tools required unless you count your hands. There is a plastic tab on both side in between the seat and carper that you pull up on and the bottom part comes out.
Seth
Past subies:
Other toys:
Old 09-01-2009, 09:24 PM
Re: fuel pump fuse
nope, no fuse.
no subaru i know of has a fuse for fuel pump.
connector only.....
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 09-01-2009, 09:27 PM
Gamesy's Avatar
Re: fuel pump fuse
my friends 05 wrx has a fuse
Originally Posted by bheinen74 View Post
nope, no fuse.
connector only.....
Old 09-02-2009, 04:15 AM
Re: fuel pump fuse
nope, no fuse.
connector only.....
Gamesy,
If you are so concerned pull fuse No. 16, which protects the fuel pump. But why worry? The pump is only energised when the ignition is activated. Keep the keys in your pocket.
Old 09-02-2009, 07:05 PM
Gamesy's Avatar
Re: fuel pump fuse
my plan is to unplug the pump and start the car therefore draining and releaving some pressure for when i unplug the lines
Originally Posted by Trevor View Post
Gamesy,
Old 09-02-2009, 08:48 PM
Re: fuel pump fuse
Good thinking.
Fuse 16 also covers the airbag system, but nothing else as far as I can ascertain. Therefore this should do the trick.
Old 09-02-2009, 08:56 PM
Re: fuel pump fuse
If your pulling fuses for anything airbag related disconnect the battery and wait 10 min before pulling it.
Seth
Past subies:
Other toys:
Old 09-02-2009, 09:22 PM
Gamesy's Avatar
Re: fuel pump fuse
ya you might end up popping the bag lol. Speaking of which anyone know the shelflife of an airbag? I seriously doubt they can last 15years
Old 09-02-2009, 10:36 PM
Re: fuel pump fuse
inspect after 10 years
Old 09-03-2009, 04:06 AM
Re: fuel pump fuse
Why is there a difference in disconnecting the battery and pulling the fuse, in respect of the B+ supply to the airbag system? Another rumour no doubt.
