Old 01-07-2009, 08:25 AM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
tranny line ballbearings?
are there ballbearings in the tranny where the tranny lines go into it?
Old 01-07-2009, 08:30 AM
Re: tranny line ballbearings?
A little more detail please??
There are many bearings in the trans... AT or MT? Which "lines"??
Old 01-07-2009, 08:45 AM
newkid17's Avatar
ok its an at., original tranny.... there are 2 lines comeing down from the engine to the tranny, there are screws going through them at the tranny to keep them there, the one screw had a spring on it, and in the tranny where the line connects i think there should be a ballbearing but i dont know if both of the lines have one...or just the one with the spring? i was taking it out and a ballbeaing fell and i figured that that is where it was from
Old 01-07-2009, 09:08 AM
newkid17's Avatar
and along with that ball bearing i also have this spacer type thing that came out into the tranny pan when we were takin the pinion out idk if anyone could help me where that goes as well?
thanxs bobby
Old 01-07-2009, 09:12 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
thanxs bobby
Attachment 11778
Attachment 11779
Yikes... This is why I just have OT work on my car.. I certianly can't take something apart, let alone put it back together..
Old 01-07-2009, 09:15 AM
longassname's Avatar
Just some dude.
the spacer thing you are talking about is a plastic ring that is broken in half? That is the thrust washer that adjusts the end lash of the whole rotating assembly. If it's fallen out then your end lash has increased by that much which basically sucks but there isn't anything you can do about it but drive it till it blows.
The ball bearing you are talking about is a check valve on the output line. There is only one.
Old 01-07-2009, 09:17 AM
newkid17's Avatar
the washe is not plastic its metal....and it is not broken in half
Old 01-07-2009, 09:18 AM
Just some dude.
wait, i just looked at the pictures...I don't know what that ring is..I don't think it's part of the transmission unless that's the washer that is supposed to be on the end of the pinion and someone somehow forgot to put it on and it ended up in the pan.
Old 01-07-2009, 09:21 AM
newkid17's Avatar
well i do have the transmission out of my car changinng the front differential so its not something someone else did whatever it is i did it.....lol
Just some dude.
if that's the washer that goes on the pinion before the drive gear then someone who shouldn't have taken your transmission apart has taken it apart.
Old 01-07-2009, 09:23 AM
Just some dude.
oh ok, I was going off of your saying it came out of the pan which it couldn't have without someone throwing it into the pan.
it goes on the pinion before the drive gear.
Old 01-07-2009, 09:32 AM
newkid17's Avatar
here is a picture of my old pinion and th shaft...is that where you are talking that the spacer goes?
Old 01-07-2009, 09:33 AM
LAN is right, that is a washer that goes on the pinion shaft behind the drivegear assembly.
Old 01-07-2009, 09:52 AM
Just some dude.
ouch, that pinion didn't break like that cause of wear...that's because the differential was impropperly installed.
The washer goes on the end of the shaft in the 2nd picture before the drive gear. That has nothing to do with the failure of the pinion though. Not having it in would cause the failure of the drive and driven gears and the support bearing. You or someone had the ring and pinon lash way off.
Old 01-07-2009, 10:41 AM
Just some dude.
What exactly have you done?
Did you remove the pump?
I'll help you out of this but I need to know what's going on and where you are at with it.
