Old 12-15-2008, 12:02 AM
jokethis89's Avatar
jokethis89 jokethis89 is offline
95 Laguna Blue 5 Speed
Send a message via AIM to jokethis89
Exclamation Oil seal problem??
I'm repeatedly having problems with the camshaft and timing cover (front main) oil seals. I got the car with 83,000mi on it, and one of the exhaust cam seals blew out before 100K (I replaced both.) About 10k mi later (after the 5mt swap I think) the timing cover seal blew out (2-3 quarts of oil on the ground in like 30 sec.) When i got home today (114k) it was dumping oil all over my driveway again... Havn't looked to see which one it is but I sure am tired of changing them.
A local subaru tech (2 actually) told me that they were suppose to go in dry like every other seal I've ever replaced, is this a common problem or is there a chance I'm installing them incorrectly??
You guys are awesome thanks for helping!
...on a side note there is oil on the outsides of both front wheels, completely covering the bottom and back of my car, and charred all over the custom dual exhaust I just finished!!!!!
Old 12-15-2008, 12:04 AM
liamrh's Avatar
liamrh liamrh is offline
Re: Oil seal problem??
Sounds like you have a crankcase pressure problem. PCV?
Old 12-15-2008, 05:08 AM
Manarius's Avatar
Manarius Manarius is offline
In addition to the PCV problem mentioned above, I bet your valve cover gaskets are worn out as well.
-Jason
-Obi Wan Kenobi
Old 12-15-2008, 11:29 AM
jokethis89's Avatar
Yea thats true huh, I bought a new pcv valve awhile back but never put it in.. I guess nows the time. Valve Cover gaskets are proving difficult to find anywhere you guys recommend?
Thanks again!!
Old 12-15-2008, 12:53 PM
Manarius's Avatar
Thanks again!!
Get them straight from Subaru and get the grommets from Napa.
-Jason
-Obi Wan Kenobi
Old 12-15-2008, 03:46 PM
dennyo dennyo is offline
are these the grommets for the bolts? are they comparable to oem? thanks dennis
Old 12-15-2008, 04:51 PM
Manarius's Avatar
Yes. They're exactly the same and about 60% of the price of the Subaru ones.
-Jason
-Obi Wan Kenobi
