Old 12-09-2008, 08:57 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Cool TCU mod
Since setting up my ECU and TCU modding website, I get a lot of emails from people telling me about their projects. Check this out:
Originally Posted by Ryan Press
Thanks for all your work on your web page and the SVX TCU. Recently I
have set out to modify my Subaru GL-10 with the 4EAT to add paddle
shifters. I decided to use a Legacy TCU and modify it. Below are the
results of my disassembly of a '90 Legacy AWD TCU; this TCU is similar to
the one in the SVX. Also included is my source code for the paddle
shifter.
I have also modded the shifting line pressure and the AWD clutch. Those
lookup tables documented in the disassembly.
Originally Posted by b3lha
I'm very impressed by your paddleshift code. You clearly have a good understanding of what you are doing. Have you had a chance to try it out yet? It's a very cool project and I'll be interested to hear how it goes.
Yes, the paddle shift is up and working great. The TCU still handles TC
lockup, line pressure, etc. It shifts pretty fast, and makes driving over
the mountains much more fun!
Would it be OK for me to tell the guys on the SVX forum about your project and show them the pictures? I know a few people have mentioned paddle shift in the past and I think they would be excited to see that it is possible.
Sure, I don't mind if you show off my project. You can even give out the paddle source.
I've looked at the Legacy TCU program and it is similar to the SVX. It should be fairly straightforward to adapt this to work with an SVX TCU. Pictures and program code attached.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 12-09-2008, 09:38 AM
Re: Cool TCU mod
Where's this website Phil?
That is a marvellous modification. The gearbox in my RVR has a tipronic gearchange, and it is much nicer to drive that way if I am not being lazy.
Phil, does this mean he has managed to make a 4EAT into a tiptronic type box? If so, that's fantastic.
Old 12-09-2008, 10:50 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Cool TCU mod
Very cool! What steering wheel/paddle lever set up is he using?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-09-2008, 11:20 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: Cool TCU mod
All of this sounds very interesting and I would love to learn more about it! I wen't to your website to check it out and there are too many big words... lol.
Anyway, could anybody sumarize this or tell me the benifits of having this done? How does it all work? What are the paddle things for?
Old 12-09-2008, 11:38 AM
RSVX RSVX is offline
Network Design Administrator
Re: Cool TCU mod
His signature might be a good place to start.
Life is a game. Play to win.
Old 12-09-2008, 01:05 PM
taylorbr's Avatar
taylorbr taylorbr is offline
Re: Cool TCU mod
That's some REALLY cool stuff on the website. It has me wondering if the hardware of the ECU/TCU is the same for different markets (USDM, JDM, UKDM) why the JDM maps look so different. In theory using some of that stuff, you could do lots of stuff - adjust the timing to run a 87 octane mode, adjust the A/F ratios to get more power, etc...
@Freeman - this stuff allows you to adjust the code that controls the engine and transmission. With the paddle mod, when you pull the lever it will tell the TCU to shift up or down, acting like one of the tiptronic transmissions. You have one paddle to shift up and one paddle to shift down.
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
Old 12-09-2008, 01:30 PM
Freeman's Avatar
Unregistered User
Re: Cool TCU mod
lol wut?
So... It's an automatic AND a manual?
Old 12-09-2008, 02:10 PM
Re: Cool TCU mod
No!
Well, when I asked the question Phil had no signature up. Maybe he was modifying it at the time?
Thanks for the steer Chris.
Old 12-09-2008, 02:13 PM
Re: Cool TCU mod
Originally Posted by Freeman View Post
lol wut?
Is that a serious question?
It is an automatic that works as an auto if you leave it alone, or you can "force" gearchanges manually by pulling on either the up paddle or the down paddle.
Old 12-09-2008, 02:29 PM
Freeman's Avatar
Unregistered User
Re: Cool TCU mod
I'm not technically or mechanically inclined WHAT so ever. I'm a computer/gamer guy.. I normally just have OT or people on the forum explain it to me. I had to wiki this one.. lol. Oh well it's not for me anyway.. I can't drive manual..
Old 12-09-2008, 02:37 PM
Re: Cool TCU mod
Brett, the gearbox remains fully automatic. There are only 2 pedals, throttle and brake pedal.
The paddles allow you to physically pull a lever that causes the software in the auto transmission to select a lower or a higher gear.
You could drive this no problem.
Old 12-09-2008, 02:41 PM
Freeman's Avatar
Unregistered User
Re: Cool TCU mod
I see.. I noticed from the pictures the things around the wheel.. I'm always worried to drive a manual in fear that I would simply muck things up. I know I'd find a way to mess up the tranny or break something.. I don't even do manual on Forza 2 cause I'm afraid I'd mess it up. Even with something like this.. If I'd make a mistake, the transmission would fix it?
Although, of course with most things, the more you do it the better you are at it. I just don't want to "re-learn" to drive..
Old 12-09-2008, 02:54 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Re: Cool TCU mod
Shelf... do the <picard>
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 12-09-2008, 05:24 PM
K_Dub's Avatar
K_Dub K_Dub is offline
Headin' for the hills
Re: Cool TCU mod
Somebody build this, please. If anyone wants to take bait, and makes a kit for install, you can be sure you'd sell at least one of these. Just make sure it costs less than a 5mt swap.
Old 12-10-2008, 04:49 PM
b3lha's Avatar
Phil & Belha
Re: Cool TCU mod
I may try this as an experiment once I get my black SVX back on the road. Sometime after Christmas.
