Old 05-22-2001, 05:08 PM
htyei's Avatar
htyei htyei is offline
SVX Animated Icon Guy!
Send a message via ICQ to htyei Send a message via AIM to htyei Send a message via Yahoo to htyei
my site, my own drooping visor fix
http://svx.enzeru.com
I just decided to pop up a page with pictures and stuff I've done with the SVX.
Major thing wanted you guys to know are the pictures I took while fixing my sunvisor!
Henry Yei
htyei@svxwrx.com
1992 Dark Teal LS-L w/o spoiler "OLIVIA"
http://www.svxwrx.com
Old 05-22-2001, 06:11 PM
zsvx
Re: my site, my own drooping visor fix
I just decided to pop up a page with pcitures and stuff ive done with the SVX.
major thing wanted you gues to know is the pictures i took while fixing my sunvisor!
So that's why my vanity lights don't work. I thought the bulbs had just burned out. I like your friend's comic as well.
"He can't even use the scanner until he gets that pencil! "
Old 05-22-2001, 07:22 PM
htyei's Avatar
vanity bulb
easies thing to check if its bulb is to swap the left and right sunvisor bulbs with each other. if the bulb worked ont heone side and not the other, most probably the wires broke.
I started out just wanting to replace the bulb myself, but ended up fixing the whole thing
Henry Yei
htyei@svxwrx.com
Old 05-24-2001, 04:21 AM
htyei's Avatar
fix not total
Fix isnt total though, It seems my stems have worn as well, still droops a bit not as much as b4.
Have no idea how to pull the stick out and what to do with iot
Henry Yei
htyei@svxwrx.com
Old 05-24-2001, 12:53 PM
zsvx
Re: fix not total
Someone posted instructions to do this. I think they put some of that heat shrink material around the stem and slid it back in. I don't remember who it was but I'm sure it will come up in a search on this board or Yahoo.
Old 05-24-2001, 01:32 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Re: fix not total
Yes, it was Mike "nubsjr." The instructions were in another thread on this site, and is also outlined in the Yahoo archive.
Randy Johnson
Mike Davis -- at Reading VI
Old 05-24-2001, 08:45 PM
Invisible avatar
Wink
And don't forget the sure-fire Viagra method!
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 05-24-2001, 10:39 PM
Aredubjay's Avatar
Thumbs up
^-- Look at my hand. How can you tell I'm holding viagra?
Randy Johnson
Old 05-25-2001, 09:21 AM
Sunvisor fix msg. no.
In the archive the sunvisor fix by nubsjr is outlined in Message 35222
Old 05-25-2001, 12:38 PM
htyei's Avatar
posted msg, + questions
Have a few questions about this. What is the "pin" of the mounting bracket. Does the ounting braket include the part with the plastic peice?(krazyglued it permanently, going to be a bear to take apart if possible at all
Visor fix revisted
Post 35222
Posted by nubsjr on 9/4/00 at 8:51 pm
Since you guys got a laugh out of my last attempt for fixing a loose visor sometime back, I went back to drawing board to redeem myself.This might not work for everbody because the wires to my vanity mirror were already broke.Take visor off of the ceiling, you may be able to get the wires fished through the mounting bracket if you take them out of the plastic connector.Then hold the visor and with a twisting motion pull the mounting bracket out of the visor.This will take some effort but it will come out.Once out, clean all of the loose plastic out of the visor.Then on the pin of the mounting bracket find a piece of electical shrink wrap tubing the fits on as snugly as possible.Slip a piece over the pin leaving it a little longer so it melts over the end.After it cools off, push it back into the visor while twisting, it pushes in hard but take your time.The tighter it is the better it will stay up.When you get it in all the way, trim off any tubing that pushed out and reinstall.If it pushes on to hard I guess you could ream out the hole in the visor a little bit. I did this about a month ago and it works great.
Henry Yei
htyei@svxwrx.com
Old 08-05-2001, 09:19 AM
uconnscott
I came to print the visor fix instructions (i saw them previously and they looked very good. However, I can't get to the link. Getting error message (server problems??). Please let me know when This sight comes becomes available or any other way to get the "visor fix" instructions. My visors sag badly and it would be greatly apprecitated. Thank!
Old 08-05-2001, 11:48 AM
htyei's Avatar
here it is
http://www.svxwrx.com/
i moved to my own domain a while back
word of warning, it seems what i did turned into a temporary fix, it came back for me and another member after a few weeks.
make sure only your little plastic holder on the visor is loose, not that and the fact that your entire stem seems very loose.
Henry Yei
htyei@svxwrx.com
Old 08-06-2001, 05:29 PM
uconnscott
Thumbs up
Thanks for the tip.....actually right after i posted that reply, i was able to find your sight, and the instructions.
I hate to hear that that fix didn't work. I was all set to try to do it. I have to believe there is some way to fix it permantly. I wouldn't care so much, but it sags badly in my car and it really is a pain. I am willing to put good time/money into fixing it.
Do you think a subaru dealer would be of any use?? Just so you don't get the wrong idea, I just bought my '92 and it is at the body shop now (already had radiator, tranny cooler, belts, etc. done at shop) and i get the car back thurs. or friday. I just want to fix the one last thing that really annoys me. I am still searching for a total success story. Will certainly follow up with you if i find one! Thanks again.
Old 08-06-2001, 11:41 PM
Aredubjay's Avatar
Mike (nubsjr) has a fix using shrink tubing. If you do a search here, or on the Yahoo archives, it should turn up. Mine are beginning to droop, so, I'll have to figure something out soon. I have a spare driver's side that doesn't droop, so, that'll be my fix for the driver's side. Will have to find something else for the passenger's side . . . besides slapping my wife's hands every time she goes for the visor.
Randy Johnson
Old 08-07-2001, 02:26 AM
htyei's Avatar
hey dont touch that visor!
Haha, i have to explain to everyone of my friends why i dont want them to touch the sunvisor.
Henry Yei
htyei@svxwrx.com
